Possible feature for Clone Tool?
Possible feature for Clone Tool? Chris Mohler 02 Mar 20:33
  Possible feature for Clone Tool? Martin Nordholts 03 Mar 21:53
   Possible feature for Clone Tool? Sven Neumann 04 Mar 12:40
Chris Mohler
2009-03-02 20:33:35 UTC (almost 16 years ago)
I just finished a bunch of cloning (dates inserted into digital pics) and thought of something:
When cloning, would it be possible to display the source pixels inside of the clone tool's brush outline? I think that would be quite useful for dealing with cloning when straight edges are involved, esp at odd angles. I envision a checkbox on the clone tool options for "display source" or similar, and possibly an opacity slider.
On the other hand, I'm not sure if the brush/tool implementation can handle something like this. What do you guys think?
Chris
Martin Nordholts
2009-03-03 21:53:14 UTC (almost 16 years ago)
It certainly is possible to do (after all, we're talking about software here) and to me this sounds like an improvement.
- Martin
2009-03-04 12:40:39 UTC (almost 16 years ago)
Possible, yes. But it is not easily doable with the current tools framework and it might turn out to be a performance problem.
