some strings untranslated...
some strings untranslated... Marco Ciampa 02 Feb 02:03
some strings untranslated... Ulf-D. Ehlert 02 Feb 15:07
  some strings untranslated... Marco Ciampa 03 Feb 23:30
   some strings untranslated... Ulf-D. Ehlert 04 Feb 11:56
    some strings untranslated... Marco Ciampa 04 Feb 22:45
Marco Ciampa
2009-02-02 02:03:27 UTC (about 16 years ago)
I see some strings as untranslated.
For example the title "How do I Become a GIMP Wizard?" appears untranslated in the italian version but in:
/po/it$ grep -Ri wizard * gimp.po:msgid "How do I Become a GIMP Wizard?"
it _is_ translated!
Any hint?
Ulf-D. Ehlert
2009-02-02 15:07:50 UTC (about 16 years ago)
Hi Marco,
Marco Ciampa (Montag, 2. Februar 2009, 02:03):
it _is_ translated!
Any hint?
Probably your xml file is newer than the po file, so it won't be updated. Try
prompt> ls -ltr src/gimp.xml pot/gimp.pot po/it/gimp.po xml/it/gimp.xml to verify this, then
prompt> touch src/gimp.xml
and
prompt> make [-f Makefile.GNU] xml/it/gimp.xml should create a file with correct translation: prompt> grep 'Come diventare un mago' xml/it/gimp.xml Come diventare un mago di GIMP?
Bye, Ulf
Marco Ciampa
2009-02-03 23:30:39 UTC (about 16 years ago)
On Mon, Feb 02, 2009 at 03:07:50PM +0100, Ulf-D. Ehlert wrote:
Hi Marco,
it _is_ translated!
Any hint?
and
$touch src/gimp.xml
$make xml/it/gimp.xml
$make: Nothing to be done for `xml/it/gimp.xml'.
Ulf-D. Ehlert
2009-02-04 11:56:24 UTC (about 16 years ago)
Marco Ciampa (Dienstag, 3. Februar 2009, 23:30):
$touch src/gimp.xml
$ touch src/gimp.xml
$ LANG=C make xml/it/gimp.xml
$ grep "ALL_LINGUAS =" Makefile ALL_LINGUAS = en de
$ make xml/it/gimp.xml ALL_LINGUAS=it [DEP] xml/it/.deps.mk
[POT] pot/gimp.pot
[PO] po/it/gimp.po
Bla bla
[XML] xml/it/gimp.xml
Did you ran ./autogen.sh with a wrong language argument (e.g. ALL_LINGUAS="enit")?
Bye,
Ulf
Marco Ciampa
2009-02-04 22:45:15 UTC (about 16 years ago)
$touch src/gimp.xml
[POT] pot/gimp.pot
[PO] po/it/gimp.po
Bla bla
Strange...I have run this:
ALL_LINGUAS="en it" ./autogen.sh --prefix=/usr --without-gimp
and it worked well in past...
