Gimp2.6.4 for ARM processor
18 of 18 messages available
Gimp2.6 Install issue sanju More 17 Jan 12:34
  Gimp2.6 Install issue Martin Nordholts 17 Jan 12:38
  Gimp2.6 Install issue Daniel Hornung 17 Jan 12:39
Gimp2.6 Install issue sanju More 17 Jan 12:43
  Gimp2.6 Install issue Sven Neumann 17 Jan 14:36
Gimp2.6 Install issue sanju More 17 Jan 12:44
  Gimp2.6 Install issue Kevin Cozens 17 Jan 16:51
Gimp2.6.4 for ARM processor sanju More 20 Jan 08:12
Gimp2.6.4 for ARM processor sanju More 20 Jan 11:44
  Gimp2.6.4 for ARM processor jcupitt@gmail.com 20 Jan 11:57
Gimp2.6.4 for ARM processor sanju More 20 Jan 12:36
  Gimp2.6.4 for ARM processor jcupitt@gmail.com 20 Jan 12:43
  Gimp2.6.4 for ARM processor Daniel Hornung 20 Jan 12:46
Gimp2.6.4 for ARM processor sanju More 20 Jan 13:03
  Gimp2.6.4 for ARM processor Sven Neumann 21 Jan 22:20
Gimp2.6.4 for ARM processor sanju More 20 Jan 15:44
  Gimp2.6.4 for ARM processor Tor Lillqvist 20 Jan 19:52
Gimp2.6.4 for ARM processor sanju More 21 Jan 05:47
sanju More
2009-01-17 12:34:19 UTC (over 16 years ago)
Hi All,
I am facing some issues while installing gimp2.6. See below log
checking for _NL_MEASUREMENT_MEASUREMENT... yes checking whether NLS is requested... yes checking for intltool >= 0.35.5... ./configure: line 23764: intltool-update: command not found found
configure: error: Your intltool is too old. You need intltool 0.35.5 or later.
Then i tried to install intltool-0.40.5, some perl issue i am facing see below log messages
checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk
checking whether make sets $(MAKE)... yes checking for perl... /usr/local/bin/perl checking for XML::Parser... configure: error: XML::Parser perl module is required for intltool
Please let me know any comments .
Regards, Sanjeev
Martin Nordholts
2009-01-17 12:38:17 UTC (over 16 years ago)
sanju More wrote:
Hi All,
Hi
What platform are you on? I think I got that problem when I went through the process of building GIMP on Windows. I ended up getting using a prebuilt version I got from another developer.
In anycase, just make sure the XML::Parser module is available, that should fix your problem.
- Martin
Daniel Hornung
2009-01-17 12:39:35 UTC (over 16 years ago)
Well, is the Perl xml parser installed?
Daniel
sanju More
2009-01-17 12:43:25 UTC (over 16 years ago)
Hi Martin,
I am working on Linux platform ( Fedora 6).
-Sanjeev
sanju More wrote:
Hi All,
Hi
- Martin
sanju More
2009-01-17 12:44:20 UTC (over 16 years ago)
It is installed, please let me know how to check that is installed.
-Sanjeev
----- Original Message ---- From: Daniel Hornung
To: gimp-developer@lists.xcf.berkeley.edu Sent: Saturday, 17 January, 2009 5:09:35 PM Subject: Re: [Gimp-developer] Gimp2.6 Install issue
Daniel
2009-01-17 14:36:49 UTC (over 16 years ago)
If you want to work with recent software and compile from source, then you should consider to upgrade your distribution. Fedora 6 is rather old and it will save you a lot of trouble if you update to a more recent version.
Kevin Cozens
2009-01-17 16:51:33 UTC (over 16 years ago)
When I was first going through my e-mail I read the above as Fedora 8. If you are using a Fedora which is that old you will soon discover that a lot more packages than just XML::Parser are missing or out-of-date on your system.
If you are having trouble handling the missing(?) XML::Parser package, getting updated glib, gtk+ and other libraries on your system will pose an even bigger challenge. You won't be able to just install updated versions of some of those packages in the usual places without risk of breaking your system.
Checking my Fedora 8 machine, I find the following. /usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi/XML/Parser.pm
I think that is the XML::Parser module for Perl. The "5.8.8" part will vary depending on which version of Perl you have on your computer.
BTW, are you aware that Fedora 10 just came out recently?
sanju More
2009-01-20 08:12:37 UTC (over 16 years ago)
I want to know is it possible to port Gimp2.6.4 Arm processor. i downloaded the Gimp2.6.4 source code and i want build this for ARM processor. Is it possible to port this to arm processor?
- Sanjeev
----- Original Message ---- From: Kevin Cozens
To: gimp-developer
Sent: Saturday, 17 January, 2009 9:21:33 PM Subject: Re: [Gimp-developer] Gimp2.6 Install issue
sanju More
2009-01-20 11:44:53 UTC (over 16 years ago)
Is it possible to cross compile gimp2.6.4? i am trying to cross compile gimp2.6.4 with arm-linux-gcc. Pleae let me know the procedure to do this.
Is there any toolchains required?
- Sanjeev More
jcupitt@gmail.com
2009-01-20 11:57:29 UTC (over 16 years ago)
2009/1/20 sanju More :
I cross-compile from x86 linux to windows and I imagine it's pretty similar. You need to build the cross-compiler (perhaps you have this already?), then build the software stack that gimp depends upon, then build gimp.
Google suggests:
http://www.ailis.de/~k/archives/19-ARM-cross-compiling-howto.html
John
sanju More
2009-01-20 12:36:40 UTC (over 16 years ago)
Thanks for your input. i downloaded gimp2.6.4, i configured this with some packages like(babl,gegl,glib....) and i did make and make install on fedora 10 host machine. This is working fine.
But i need gimp2.6.4 to be cross compiled with arm-linux-gcc. For this i need to cross compile all these packages(babl,gegl,glib...) and then gimp2.6.4 or just i need compile gimp2.6.4
-- Sanjeev
----- Original Message ---- From: "jcupitt@gmail.com"
To: sanju More
Cc: gimp-developer
Sent: Tuesday, 20 January, 2009 4:27:29 PM Subject: Re: [Gimp-developer] Gimp2.6.4 for ARM processor
Google suggests:
John
jcupitt@gmail.com
2009-01-20 12:43:12 UTC (over 16 years ago)
I'm afraid you'll have to build almost averything, from glibc up. What's your target machine? You should maybe try to get hold of the glibc they use.
John
Daniel Hornung
2009-01-20 12:46:13 UTC (over 16 years ago)
-- Sanjeev
You'll need to have all the dependencies available on the other platform as well, which probably means you'll have to cross-compile them.
Daniel
sanju More
2009-01-20 13:03:07 UTC (over 16 years ago)
Please tell me the procedure to cross compile all these.
My target board S3C2410.
-Sanjeev More
To: gimp-developer@lists.xcf.berkeley.edu Sent: Tuesday, 20 January, 2009 5:16:13 PM Subject: Re: [Gimp-developer] Gimp2.6.4 for ARM processor
-- Sanjeev
Daniel
sanju More
2009-01-20 15:44:47 UTC (over 16 years ago)
i am trying to cross compile gegl-0.0.22 with command CC=arm-linux-gcc ./configure arm-linux --target=arm-linux --with-shared --prefix=/usr. I am getting below mentioned error. what is this error exactly configure: WARNING: you should use --build, --host, --target checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk
checking whether make sets $(MAKE)... yes checking for arm-linux-gcc... arm-linux-gcc checking for C compiler default output file name... a.out checking whether the C compiler works... configure: error: cannot run C compiled programs. If you meant to cross compile, use `--host'. See `config.log' for more details.
i changed if test "$cross_compiling" = maybe; then cross_compiling=yes
to
if test "$cross_compiling" != maybe; then cross_compiling=yes
then i got below mentioned error
checking for GTK... yes checking for bind_textdomain_codeset... no configure: error:
*** Check for bind_textdomain_codeset() failed! This is required.
--Sanjeev
-- Sanjeev
Daniel
Tor Lillqvist
2009-01-20 19:52:54 UTC (over 16 years ago)
When cross-compiling you should use --host, not --target, to specify the architecture the executables you are building will run on. --target is used when configuring compilers and similar tools, to specify the architecture of the object files the tools will operate on.
--tml
sanju More
2009-01-21 05:47:58 UTC (over 16 years ago)
You mean to say i have to use this CC=arm-linux-gcc ./configure arm-linux --host=arm-linux
--Sanjeev
----- Original Message ---- From: Tor Lillqvist
To: sanju More
Cc: daniel.hornung@gmx.de; gimp-developer@lists.xcf.berkeley.edu Sent: Wednesday, 21 January, 2009 12:22:54 AM Subject: Re: [Gimp-developer] Gimp2.6.4 for ARM processor
--tml
2009-01-21 22:20:08 UTC (over 16 years ago)
Please stay on-topic. Cross-compilation is not a topic for the gimp-developer mailing-list. There are very good HOWTOs available that describe how to cross-compile free software using free toolchains. It doesn't really make any difference if you want to cross-compile GIMP or any other application / library.
Should you run into a particular problem that is directly related to the GIMP code, then you are of course free to ask here and we will do our best to solve that problem.
