ANNOUNCE: GIMP 2.6.2
ANNOUNCE: GIMP 2.6.2 Sven Neumann 30 Oct 22:21
  ANNOUNCE: GIMP 2.6.2 Alec Burgess 01 Nov 22:37
2008-10-30 22:21:19 UTC (over 16 years ago)
GIMP 2.6.2 is a bug-fix release in the stable GIMP 2.6 series. The source can be downloaded from ftp.gimp.org or one of the mirrors listed at http://gimp.org/downloads/#mirrors
Binary packages for the various supported platforms should become available soon; please check the Downloads section on www.gimp.org.
Overview of Changes from GIMP 2.6.1 to GIMP 2.6.2 =================================================
* Bugs fixed:
557950 – Scaling in Gimp 2.6 is much slower than in Gimp 2.4 558215 – unit and zoom entries in Statusbar not visible 558451 – Cannot build GIMP using Sun CC on Solaris 2.8 558420 – projection incorrect with alpha-less layers 556603 – Zoom region always zooms in center of image 557870 – "Qmask" message popping up here and there 557705 – compatibility with GEGL > 0.0.20 556248 – Scaling gives 'jagged' edges 556804 – Zoom drop down doesn't update 524615 – Print not to scale
555246 – gimp crashes when a file is opened while a preview is generating
556741 – Alpha layer automatically added (in psd format) 556182 – Could you please explain a few strings [I18N] 555697 – build fails if configured with --without-libjpeg 134956 – Curves tool doesn't save free curves
* Updated translations:
Czech (cs) Danish (da)
Finnish (fi)
French (fr)
Japanese (ja)
Polish (pl)
Brazilian Portuguese (pt_BR)
Swedish (sv)
Simplified Chinese (zh_CN)
Alec Burgess
2008-11-01 22:37:54 UTC (over 16 years ago)
Sven Neumann (sven@gimp.org) wrote (in part) (on 2008-10-30 at 17:21):
GIMP 2.6.2 is a bug-fix release in the stable GIMP 2.6 series. The source can be downloaded from ftp.gimp.org or one of the mirrors listed at http://gimp.org/downloads/#mirrors Binary packages for the various supported platforms should become available soon; please check the Downloads section on www.gimp.org.
Jernej - thanks for getting the Windows build of 2.6.2 out so quickly.
The problem with zooming going out of image appears to be corrected - great, but
I'm still seeing the same Help-Internal browser problem:
The GIMP help browser plug-in appears to be missing from your installation. You may instead use the web browser for reading the help pages.
I thought that this was something required some tweak to the Windows build and was going to be fixed for 2.6.2. Did I misunderstand?
My system WinXP SP3.
