[wish] provide transparent color
[wish] provide transparent color | Maciej Pilichowski | 23 Sep 20:38 |
48D93A6A.8090105@dbp-consul... | Patrick Horgan | 23 Sep 20:50 |
[wish] provide transparent color | Simon Budig | 23 Sep 20:53 |
[wish] provide transparent color | David Odin | 23 Sep 20:55 |
[wish] provide transparent color | bgw | 23 Sep 21:19 |
[wish] provide transparent color | Daniel Hornung | 24 Sep 00:05 |
[wish] provide transparent color | Chris Moller | 23 Sep 21:21 |
mailman.1.1222196404.19391.... | 07 Oct 20:26 | |
[wish] provide transparent color | Maciej Pilichowski | 23 Sep 21:19 |
[wish] provide transparent color | Simon Budig | 23 Sep 21:44 |
[wish] provide transparent color | Michael Schumacher | 24 Sep 00:35 |
[wish] provide transparent color | David Odin | 23 Sep 21:44 |
mailman.214322.1222207519.1... | 07 Oct 20:26 | |
[wish] provide transparent color | Maciej Pilichowski | 24 Sep 08:17 |
[wish] provide transparent color | David Gowers | 24 Sep 11:03 |
[wish] provide transparent color | Maciej Pilichowski | 24 Sep 11:45 |
[wish] provide transparent color | Chris Moller | 24 Sep 13:53 |
[wish] provide transparent color | Daniel Hornung | 25 Sep 09:36 |
[wish] provide transparent color | Chris Moller | 25 Sep 13:36 |
[wish] provide transparent color | Daniel Hornung | 25 Sep 16:41 |
mailman.215598.1222361411.1... | 07 Oct 20:26 | |
[wish] provide transparent color | Alchemie foto\\grafiche | 25 Sep 20:05 |
[wish] provide transparent color | Sven Neumann | 25 Sep 21:42 |
[wish] provide transparent color | Patrick Horgan | 25 Sep 21:59 |
[wish] provide transparent color | Salvatore De Paolis | 25 Sep 22:30 |
mailman.3.1222369204.13775.... | 07 Oct 20:26 | |
[wish] provide transparent color | Maciej Pilichowski | 27 Sep 19:21 |
I was asked to bring this issue to the ML instead of discussing it on bugzilla so here we go.
Original post: http://bugzilla.gnome.org/show_bug.cgi?id=553003
Please, provide transparent color or in other words -- treat transparency _also_ as a color.
I know GIMP has alpha channel and it provides transparency. However it is artificial for me that you have colors and then you have distinct entity -- transparency. It would be useful (and _intuitive_) to have black color, white color, ... and transparent "color", so user could pick up color dialog, choose transparent and paint/draw with transparency.
Such metaphor is more accurate to real world and thus more appealing to weekend artist (who would like to do some things in simple manner).
Kind regards,
I don't think that this is a sensible approach in general.
We currently use alpha to do proper antialiasing, compositing existing photos on top of each other and in all of these cases a coupled "alphacolor" (= color + alpha value) would be cumbersome and unhelpful.
Note, that Gimp is not designed with the "weekend artist" in primary focus. But even taking him into account the current model has served us well for the last years and there has been very few discussion about this specific problem, if it cropped up it was in the context of indexed PNGs with "alphacolors" or generating textures for renderers. For the general public the current model seems to generally work and I don't see a compelling reason to change this.
Bye, Simon
In the real world I live in, I have yet to see a transparent pencil.
Kind regards,
Why unhelpful? Note, that you are already used to something, and different does not mean unhelpful. I would love to change colors (including transparency) so I could focus only on several tools. For me using alpha channel just to make something transparent is tiresome because I have to use more tools than I really need.
Well, one thing is history -- everything (in general) worked in the past -- why introduce cars when horses... etc etc etc :-)
The second thing is potential benefit -- and I believe less time spent on creating an image _is_ benefit. Note, that it will not introduce new features per se, it only could only change the way you work (if one wishes so). You can work with colors with color tools and you can only work with alpha channel with alpha channel tools. It is narrowing possibilities -- why not pick up brush, shape, pressure and polish a picture edges with transparency (as color)?
Wish granted -- simply use your finger (I assume you thought of glass painting because it is only good metaphor source for working with alpha channel in the first place).
Kind regards,
Doesn't the Eraser Tool do what you need? (Though maybe some interesting effects could be gotten with an erasing airbrush that accumulated in the alpha channel. On more thing for the long-term, idle-moment TODO list.)
Well, historically new stuff always had to proove that it is better than the old stuff and I personally don't think that is a bad thing.
I guess I have not yet understood what you actually want to achieve.
So how do you want to work with transparency? What should happen if you have a semi-transparent red and you paint on top of blue? Currently it gets blended on top of the blue resulting in some kind of violet and that is a widely used feature to do natural looking paintings. I understand your proposal, that you actually want to have a semi-transparent red in the image after painting?
How is your new feature supposed to interact with tablets with varying pressure devices like tablets? Right now you can map the pressure information pretty naturally to the opacity. Your "replacement" approach for alphacolors would directly influence the images alpha channel, making it pretty tricky to lift off the pen without leaving a transparent spot (tablets tend to add some events at the end et the stroke with very low pressure).
How is your "replacement" approach supposed to work with multiple layers?
I see lots of open questions here and I have doubts that your desired workflow is an improvement over the current one. Also I think that most of the tasks you mention in other mails - like cleaning up edges - can nicely be done with the current gimp, provided that you don't need 100% exact control over the alpha values (like the texture guys seem to need it, but they are not the main target audience). So I still don't see the problem here that needs to be solved.
Bye, Simon
On Tue, Sep 23, 2008 at 09:19:09PM +0200, Maciej Pilichowski wrote:
In the real world I live in, I have yet to see a transparent pencil.Wish granted -- simply use your finger (I assume you thought of glass painting because it is only good metaphor source for working with alpha channel in the first place).
So your wishes are granted too. There are already tools for that in the gimp toolbox: eraser and smudge.
On Tuesday 23 September 2008, bgw wrote:
How does "draw with transparency" differ from using eraser tool with x% opacity?
You could change the color information at the same places (and less importantly in a single step) you change the alpha information. At least that's how I understand it. Imagine painting with a solvent-diluted color, somehow. It might prove useful, although it might also interfere with current workflows.
My 2¢, Daniel
We do have an old feature request which does deal with different ways of
changing alpha by layer masks:
http://bugzilla.gnome.org/show_bug.cgi?id=128118
HTH, Michael
Pencil and eraser are counterparts of course, but I wished for transparent color, not just transparent pencil (yes, it exists, and it is eraser).
Yes and no, see above.
(Though maybe some
Exactly! Because once you have transparency as your color you could use any tool which works with colors.
Of course.
Good example, because it shows how natural transparent color is. The answer: you should get exactly the same effect if you have blue color and paint on top of semi-transparent red. It depends on mode and used tool.
Both answers are really correct -- see above.
I don't understand that paragraph: a) the transparent color is not a replacement, I clearly stated this in original post, it is addition to the color palette b) don't pick the transparent color if you don't need it
Again, it is not a replacement.
Honestly, I didn't thought of this issue -- it can be done, but to achieve intuitive behaviour it should be well designed not to change too many things. So here is the problem now... pity.
See above.
Kind regards,
Hi Maciej,
On Wed, Sep 24, 2008 at 3:47 PM, Maciej Pilichowski wrote:
How does "draw with transparency" differ from using eraser tool with x% opacity?Pencil and eraser are counterparts of course, but I wished for transparent color, not just transparent pencil (yes, it exists, and it is eraser).
Doesn't the Eraser Tool do what you need?Yes and no, see above.
(Though maybe some
interesting effects could be gotten with an erasing airbrush that accumulated in the alpha channel.Exactly! Because once you have transparency as your color you could use any tool which works with colors.
Well, historically new stuff always had to proove that it is better than the old stuff and I personally don't think that is a bad thing.Of course.
There is no way to achieve the effect you describe without it being a
replacement effect.
This is because it violates the normal behaviour of alpha, which is a
specifier of opacity for a particular color; without a color, an alpha
value is meaningless.
Also, the 'semitransparent color' usage and the 'erasing' usage are directly contradictory. Semitransparent color could work in a fairly normal way, erasing would have to replace the underlying pixel values rather than blending them.
If you want to develop this idea further -- personally I think it's an interesting idea -- I believe it will be necessary to discard the notion of a 'color' which is fully transparent, ie. the notion of being able to erase just by 'color' adjustment.
David
On Wednesday 24 September 2008 11:03:43 David Gowers wrote: This is because it violates the normal behaviour of alpha, which is a specifier of opacity for a particular color; without a color, an alpha value is meaningless.
Like black color is a max.dark blue (or red, or even white) it is similar to totally transparent color -- it is black/white/red/etc with opacity reduced to 0%.
Why? Look -- transparent color is a way to produce an image. You can do this already (produce an image). So the effect is the same, the way differs. And now, you would like to erase part of the image
So there is obstacle, indeed. And till now I have no idea how to solve this.
Might be a bit of a wild branch on this topic, but I'm wondering if all the effects described here could be implemented as a /subtractive/ process.
I haven't looked at gimp's implementation, but generally speaking colors combine as Cr = Ce * ( 1- o) + Cb * o, where Cr is the resultant color (clamped full saturation of each of it's components), Ce is the existing color, Cb is the brush color, and a is the opacity. What if, instead, you made Cr = Ce * (1 - o) - Cb * o, with Cr clamped at 0? All this doesn't fiddle with the alpha channel at all, but might get the desired effect.
Kind regards,
Isn't that pretty much what the 'subtract' mode does? And yes, it doesn't
involve the alpha channel.
http://docs.gimp.org/en/gimp-concepts-layer-modes.html
Daniel
Isn't that pretty much what the 'subtract' mode does? And yes, it doesn't involve the alpha channel.
Yeah, I expect it's the same function, but adding a transparent layer, painting it, switching to subtract mode, and merging down, is more cumbersome than just painting in subtract mode would be.
cm
Daniel
------------------------------------------------------------------------_______________________________________________ Gimp-developer mailing list
The documentation site only refers to those modes as layer modes, whereas you can actually set the mode for any painting tool you use, so it's not really quite as cumbersome.
Excuse the double post in the first the subject went somehow lost and the rest reformatted in a weird way with question marks filling blank spaces -------------------------------------------------------------------------------------- May be that this long discussion suffers a lack of communication?
to summarize
brushing a transparent color" is exactly as use the eraser (if there is
a alpha channel) Maciej Pilichowski seems agree on this point
SO
what is missed
seems just a equivalent of "AIRbrushing a transparent
color",,..a option in the eraser tool to use airbrush instead then a
brush will solve that, and for sure will be a cool new feature.
May
be is missed, also the possibility to select transparent area as was a
color,meaning using the magic wand or the color selector tool..
But since there is "alpha to selection"(=select transparency) that is no too missed... well IS missed its usability since that option is hided in a weird place and is not too clearly labeled( Layer menu really do not seems most intuitive place to search function related to Selections)
For usability may be good add to the "select by color" dialog a checkbox "select transparency",..that checkbox if checked will simply call "alpha to selection" function and then invert selection(this from a developer's point of view..from average user's point of view that will just "select the transparency " as required)
To my logic (inverted)"alpha to selection" may be well seen as a subset of "select by color" (in this case will be "select by absence of colors " that as concept seems strictly related and may be called more clearly "select transparency"
i believe a "use airbrush" option for eraser tool and a "select transparency" checkbox added to " select by color" will be a nice addition also for who is no much interested to " paint with transparent color"
then a question for Maciej Pilichowski..i understand you well?
a
"airbrush-eraser" to allow to "airbrush transparent color" and a more
intuitive place and name for "select transparency" will realize your
wishes?
A palette with transparent color will be meaningless since if transparent the color will be not visible
already gimp has gradients with "transparent Color"
___
sorry, but your mail is still so badly formatted that I simply refuse to even attempt to read it. Could you please stick to the rules of the mailing-list and send text-only mails instead of this HTML crap with tables? Thank you very much.
Please don't think I'm advocating for HTML mail for the list I'm not, just had a brain fart. Does anyone else find it ironic that a mailing list having to do with high quality graphics is text only?
Patrick
Patrick
HTML in mailing list is something really annoying, and it's sad to state that many people still post as HTML. Often this is due to lazy poster which can't override default HTML in composing messages. imho HTML in messages always suck, it's only bearable in RSS feeds.
My two cents Sal
May
be is missed, also the possibility to select transparent area as was a color,meaning using the magic wand or the color selector tool..
Well, I don't mind internals at all -- what I wish that for user (frontend) Gimp could behave like transparency would be also a color. You like working with alpha channel and using distinct set of tools -- voila, you like to work with color tools only -- voila.
Just an example: how to create black area. Select area and fill it
with black color. How to create transparent area. Select area and cut
it off.
This not the best example, because one can always argue "what is so
hard to learn that you have to cut it off", but my point is -- why
learn extra way in the first place. You are a master of fill feature,
you set options, you change the fill "color". Occam's razor.
The same applies to other tools. Again, every effect is doable now, but the UI would be much cleaner with the notion "colors", not "color, and oh that extra transparency channel" so it is treated like something alien among colors (in nature it is not -- water, glass, air are transparent as well as the chalk, snow, paper are white).
But it can be presented in meaningful way, as much as it is now in the image.
Kind regards,
