/Filters/Render/Stroke to SVG...
11 of 11 messages available
newb questions re python-fu paul taney 22 Sep 17:29
  newb questions re python-fu Chris Mohler 22 Sep 18:50
   newb questions re python-fu paul taney 22 Sep 19:37
    newb questions re python-fu Chris Mohler 22 Sep 19:44
     newb questions re python-fu paul taney 23 Sep 00:41
      newb questions re python-fu Chris Mohler 23 Sep 00:51
       newb questions re python-fu paul taney 23 Sep 20:11
     /Filters/Render/Stroke to SVG... paul taney 25 Sep 18:49
      /Filters/Render/Stroke to SVG... David Gowers 26 Sep 00:44
       /Filters/Render/Stroke to SVG... paul taney 26 Sep 01:26
        /Filters/Render/Stroke to SVG... David Gowers 26 Sep 05:29
paul taney
2008-09-22 17:29:30 UTC (about 17 years ago)
A coupla questions from the newb...
I am trying to write my first python-fu plug-in and I cannot get it to install. Here"s how I am pushing it to the plugins dir:
cp VanDerWalt.py ~/.gimp-2.4/plug-ins/python-fu-vanderwalt.py chmod +x ~/.gimp-2.4/plug-ins/python-fu-vanderwalt.py
Then I look for it under /Filters/Render/ and it is not there.
It"s a color filter that attempts to extract the bluest pixels, like this:
RED, GRN, BLU = 0, 1, 2 bluemask = (image[...,BLU] > 1.4*image[...,GRN]) & \ (image[...,BLU] > 1.4*image[...,RED])
blue_layer = gimp.layer(bluemask, width, height, RGBA_IMAGE, 100, NORMAL_MODE) image.addlayer(blue_layer, 0)
Q1) Is this even close? Q2) can I continue to use numpy (as I was with wx.Python) or do these images have to be treated with scipy?
This is a volunteer project for the International Environmental Data Rescue Org (http://iedro.org), so if somebody wants to help me with it... the script is attached though it has not run yet :-o
It is for converting rasterized weather charts (stripcharts) to vector data for weather modeling.
paul
Chris Mohler
2008-09-22 18:50:19 UTC (about 17 years ago)
Hi Paul,
I found a few mistakes here and there. The main one is that Python is very strict about indentation. After that, the "import Interpolate" line I changed to "from scipy import interpolate as ma" - I'm not sure if that is correct or not. Lastly, there were some items like "PF_ITEM("foo", _("foo"), "foo")" that I changed to "PF_ITEM("foo", "foo", "foo")" and also I added "Vanderwalt" to the end on the plug-in resgistration. Oh yeah - I also added an 'except' in somewhere befor a "finally"...
So... now it still does not run correctly, but at least it registers with GIMP :|
BTW - starting GIMP from the command line will show syntax errors in py-fu scripts.... Also editors like scite and eric (among others) show indentation problems in Python by default - these are probably in your repositories.
HTH,
Chris
paul taney
2008-09-22 19:37:27 UTC (about 17 years ago)
Thanks very much, Chris.
I am using your file now and made a coupla repairs, afaict. But it still doesnt install. Now I may know why, as running it straight up gives No module named gimpfu!
I am on a Mac. Did the gimp2.4.5...dmg not compile gimpfu? Answer may be: Look for a dot .so file:
find /Applications/Gimp.app/ -name gimpfu\* | grep \.so /Applications/Gimp.app//Contents/Resources/lib/gimp/2.0/python/gimpfu.py /Applications/Gimp.app//Contents/Resources/lib/gimp/2.0/python/gimpfu.pyc /Applications/Gimp.app//Contents/Resources/lib/gimp/2.0/python/gimpfu.pyo == false positive.
What should I do next?
paul ----
% cd /Users/paultaney/gimp/gimp-2.4.7/plug-ins/pygimp/plug-ins % ./python-fu-Vanderwalt.py
Traceback (most recent call last):
File "./python-fu-Vanderwalt.py", line 20, in from gimpfu import * # imports the symbols gimp, pdb, register and main ImportError: No module named gimpfu
...is still the case. I am also pushing it twice, like: % cp python-fu-vanderwalt.py ~/.gimp-2.4/plug-ins % chmod +x ~/.gimp-2.4/plug-ins/python-fu-vanderwalt.py % cp python-fu-vanderwalt.py ~/gimp/gimp-2.4.7/plug-ins/pygimp/plug-ins % chmod +x ~/gimp/gimp-2.4.7/plug-ins/pygimp/plug-ins/python-fu-vanderwalt.py
Hi Paul,
"PF_ITEM("foo",
a "finally"...
with GIMP :|
your repositories.
HTH,
Chris
Chris Mohler
2008-09-22 19:44:23 UTC (about 17 years ago)
AFAIK, you can't run gimp-fu scripts outside of GIMP. There is a python-fu console (XTNS->Python-Fu->Console) that will allow you to type/paste code in.
When it doesn't register, is there any console output from GIMP?
Chris
paul taney
2008-09-23 00:41:02 UTC (about 17 years ago)
afaict.
running
No, but if I try to import it in the console I get something revealing:
import python-fu-vanderwalt
File "", line 1
SyntaxError: invalid syntax
I would not be suprised if python objects to minus signs in module names, so I have fixed that in my push script:
% cat push.sh cp python-fu-vanderwalt.py ~/.gimp-2.4/plug-ins/python_fu_vanderwalt.py chmod +x ~/.gimp-2.4/plug-ins/python_fu_vanderwalt.py cp python-fu-vanderwalt.py ~/gimp/gimp-2.4.7/plug-ins/pygimp/plug-ins/python_fu_vanderwalt.py chmod +x ~/gimp/gimp-2.4.7/plug-ins/pygimp/plug-ins/python_fu_vanderwalt.py
Still, it does not appear in the Xtns browser or /Filters/Render.
Maybe it has to be Capitalized , as in the script...
Nope. That"s not it; I just tested for that, but it is something REALLY STUPID. Je garantir.
paul
Chris Mohler
2008-09-23 00:51:11 UTC (about 17 years ago)
afaict.
running
File "", line 1
Hi Paul,
I did not look at it very carefully, but there are still indentation errors. I recommend opening it in Eric - it will literally show a "bug" on the line(s) in question. You're also missing a comma on line 92...
Chris
paul taney
2008-09-23 20:11:22 UTC (about 17 years ago)
Hi Chris,
It was a versions problem: I am not running my local copy of 2.4.7, I am running the one that the .dmg installed at /Applications/Gimp.app.
Now that I"ve got that straight, I can run new scripts at
/Applications/Gimp.app/Contents/Resources/lib/gimp/2.0/plug-ins
but it will not recognize any installed at ~/.gimp-2.0/plug-ins.
I can live with that.
Sorry about the missing comma; it was late when I added that line. I am running Komodo, so I do see the parser"s hints as a rule.
Thanks again, paul
--- On Mon, 9/22/08, Chris Mohler wrote:
Subject: Re: [Gimp-developer] newb questions re python-fu To: "paul taney"
Cc: "gimp"
Date: Monday, September 22, 2008, 6:51 PM On Mon, Sep 22, 2008 at 5:41 PM, paul taney wrote:
repairs,
afaict.
why, as
running
of GIMP.
There is a
that
output
from GIMP?
File "", line 1
chmod +x
/Filters/Render.
it is something
Hi Paul,
92...
Chris
paul taney
2008-09-25 18:49:42 UTC (about 17 years ago)
Chris
I"ve got things working now and use numpy to convert bluelines to SVG lines or a python tuple that gets written out.
It could be of general interest for vectorizing if it treated a selection.
But I am converting scanned stripcharts, and the ink is blue... One y per x is all I need, and there would be a slick way to do that with numpy; I"m just using a stride for line thinning.
The part I dont understand is this; I pass my bluemask to (Fremlin"s) write_out(drawable, image) as the image, it fails the assertion and does not post...
numpy.array((image*256).round(0),"B")
def write_out(drawable, image): """by John Fremlin"""
byte_image = numpy.array((image*256).round(0),"B") # B is a ubyte width = drawable.width
height = drawable.height
bpp = drawable.bpp
sys.stderr.write("write_out::drawable.width=%i drawable.height=%i drawable.bpp=%i\n" % (width, height, bpp))
pr = drawable.get_pixel_rgn(0, 0, width, height, True) assert(byte_image.size == width * height * bpp) pr[:,:] = byte_image.tostring()
David Gowers
2008-09-26 00:44:06 UTC (about 17 years ago)
Hi Paul,
Chris
Which assertion fails?
bpp = drawable.bpp
You are passing an RGB array to this function. Are you certain that your destination drawable does not have an alpha channel (thus requiring you to pass an RGBA array)?
David
paul taney
2008-09-26 01:26:41 UTC (about 17 years ago)
--- On Thu, 9/25/08, David Gowers wrote:
Hi Paul,
output
from GIMP?
Chris
Why does he multiply the image by 256 and elsewhere divide image/256?
Line 207: assert(byte_image.size == width * height * bpp) fails, right before the blit.
byte_image =
bpp = drawable.bpp
True)
assert(byte_image.size == width * height * bpp) pr[:,:] = byte_image.tostring() # blit
I have added a test for that, as best I know how; but it still fails at 207.
if drawable.has_alpha: img = gimp.Image(width, height, RGBA_IMAGE) new_layer = gimp.Layer(img, new_layer_name, width, height, RGBA_IMAGE, opacity, NORMAL_MODE) else:
img = gimp.Image(width, height, RGB_IMAGE) new_layer = gimp.Layer(img, new_layer_name, width, height, RGB_IMAGE, opacity, NORMAL_MODE)
David Gowers
2008-09-26 05:29:38 UTC (about 17 years ago)
Hi Paul.
He's expecting an image with values ranging 0..1. If the values you are providing are 0..255, you'll need to remove both of those.
byte_image =
bpp = drawable.bpp
True)
This will not necessarily help, because your vanderwalt() routine is still producing an RGB image always.
David
