[Resolved]Missing filters in my gimp-2.4.5
Missing filters in my gimp-2.4.5 | julien | 06 May 08:22 |
Missing filters in my gimp-2.4.5 | Ulf-D. Ehlert | 07 May 11:20 |
Missing filters in my gimp-2.4.5 | julien | 07 May 21:06 |
[Resolved]Missing filters in my gimp-2.4.5 | julien | 08 May 20:53 |
[Resolved]Missing filters in my gimp-2.4.5 | Sven Neumann | 09 May 12:39 |
I resume my problem which remains unsolved:
I installed gimp-2.4.5 from rpm (in /opt/gnome/bin/gimp-2.4). I also installed it from source in /usr/local/gimp-2.4.5 (and verified that my umask was 022 before #make install).
In both cases, when I start Gimp from console, I get the message "Unable to read initialization file script-fu.init"
Gimp looks OK. I can work with it, but I can't find the "decor" and "alpha-to-logo" filters and in Xtns, Logos and script-fus are absent.
Julien
julien (Dienstag, 6. Mai 2008, 08:22):
Both 2.4 versions installed at the same time?
Try
$ find /opt/gnome /usr/local -name '*script-fu*' | xargs ls -l
or even
$ find /opt/gnome /usr /usr/local -name '*script-fu*' | xargs ls -l
What do you get?
-------------- next part --------------
A non-text attachment was scrubbed...
Name: not available
Desc: not available
Url : /lists/gimp-docs/attachments/20080507/3cc07d3b/attachment.bin
Not at the same moment, but I have the two now on my computer. The problem was the same when I had gimp installed from sources only.
I add that: - when I start gimp in su mode, all script-fu are present. - under Kate, the exploring function doesn't find script-fu.init, even if I give the path /opt/gnome/share/2.0/scripts/ or /usr/local/gimp-2.4.5/share/gimp/2.0/scripts/ But I can see script-fu.init by using Konqueror.
Try
or even
What do you get?
I get
-rwxr-xr-x 1 root root 152024 mar 30 23:34 /opt/gnome/lib/gimp/2.0/plug-ins/script-fu -rw-r--r-- 1 root root 3497 nov 28 2006 /opt/gnome/share/gimp/2.0/help/images/menus/menus-script-fu.png -rw-r--r-- 1 root root 7423 mar 30 23:33 /opt/gnome/share/gimp/2.0/scripts/script-fu-compat.init -rwxr-xr-x 1 root root 18856 mar 30 23:33 /opt/gnome/share/gimp/2.0/scripts/script-fu.init -rw-r--r-- 1 root root 2311 mar 30 23:33 /opt/gnome/share/gimp/2.0/scripts/script-fu-set-cmap.scm -rw-r--r-- 1 root root 1288 mar 30 23:33 /opt/gnome/share/gimp/2.0/scripts/script-fu-util.scm -rw-r--r-- 1 root root 52083 mar 30 23:33 /opt/gnome/share/locale/ar/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 61588 mar 30 23:33 /opt/gnome/share/locale/bg/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 47027 mar 30 23:33 /opt/gnome/share/locale/ca/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 45283 mar 30 23:33 /opt/gnome/share/locale/cs/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 7986 mar 30 23:33 /opt/gnome/share/locale/da/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 46936 mar 30 23:33 /opt/gnome/share/locale/de/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 92281 mar 30 23:33 /opt/gnome/share/locale/dz/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1939 mar 30 23:33 /opt/gnome/share/locale/el/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 43995 mar 30 23:33 /opt/gnome/share/locale/en_CA/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44971 mar 30 23:33 /opt/gnome/share/locale/en_GB/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44512 mar 30 23:33 /opt/gnome/share/locale/eo/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 47913 mar 30 23:33 /opt/gnome/share/locale/es/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 14693 mar 30 23:33 /opt/gnome/share/locale/et/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 45789 mar 30 23:33 /opt/gnome/share/locale/eu/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 27877 mar 30 23:33 /opt/gnome/share/locale/fa/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 31547 mar 30 23:33 /opt/gnome/share/locale/fi/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 47325 mar 30 23:33 /opt/gnome/share/locale/fr/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1568 mar 30 23:33 /opt/gnome/share/locale/ga/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44900 mar 30 23:33 /opt/gnome/share/locale/gl/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 36271 mar 30 23:33 /opt/gnome/share/locale/gu/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1679 mar 30 23:33 /opt/gnome/share/locale/he/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 7989 mar 30 23:33 /opt/gnome/share/locale/hr/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 48046 mar 30 23:33 /opt/gnome/share/locale/hu/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1324 mar 30 23:33 /opt/gnome/share/locale/id/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 46245 mar 30 23:33 /opt/gnome/share/locale/it/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 27608 mar 30 23:33 /opt/gnome/share/locale/ja/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 74296 mar 30 23:33 /opt/gnome/share/locale/km/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 47509 mar 30 23:33 /opt/gnome/share/locale/ko/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44705 mar 30 23:33 /opt/gnome/share/locale/lt/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 58933 mar 30 23:33 /opt/gnome/share/locale/mk/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 7885 mar 30 23:33 /opt/gnome/share/locale/ms/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 6218 mar 30 23:33 /opt/gnome/share/locale/nb/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 72866 mar 30 23:33 /opt/gnome/share/locale/ne/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 26029 mar 30 23:33 /opt/gnome/share/locale/nl/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 2621 mar 30 23:33 /opt/gnome/share/locale/oc/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 58118 mar 30 23:33 /opt/gnome/share/locale/pa/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44979 mar 30 23:33 /opt/gnome/share/locale/pl/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 46948 mar 30 23:33 /opt/gnome/share/locale/pt_BR/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 8124 mar 30 23:33 /opt/gnome/share/locale/pt/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1235 mar 30 23:33 /opt/gnome/share/locale/ro/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 58964 mar 30 23:33 /opt/gnome/share/locale/ru/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 2839 mar 30 23:33 /opt/gnome/share/locale/rw/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 26667 mar 30 23:33 /opt/gnome/share/locale/sk/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 45545 mar 30 23:33 /opt/gnome/share/locale/sl/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 7952 mar 30 23:33 /opt/gnome/share/locale/sr at Latn/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 9555 mar 30 23:33 /opt/gnome/share/locale/sr/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44552 mar 30 23:33 /opt/gnome/share/locale/sv/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 5882 mar 30 23:33 /opt/gnome/share/locale/tr/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 430 mar 30 23:33 /opt/gnome/share/locale/tt/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 57265 mar 30 23:33 /opt/gnome/share/locale/uk/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 28806 mar 30 23:33 /opt/gnome/share/locale/vi/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 29184 mar 30 23:33 /opt/gnome/share/locale/xh/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1084 mar 30 23:33 /opt/gnome/share/locale/yi/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 23284 mar 30 23:33 /opt/gnome/share/locale/zh_CN/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 17510 mar 30 23:33 /opt/gnome/share/locale/zh_TW/LC_MESSAGES/gimp20-script-fu.mo -rwxr-xr-x 1 root root 401707 mai 2 15:15 /usr/local/gimp-2.4.5/lib/gimp/2.0/plug-ins/script-fu -rw-r--r-- 1 root root 7423 mai 2 15:15 /usr/local/gimp-2.4.5/share/gimp/2.0/scripts/script-fu-compat.init -rw-r--r-- 1 root root 18856 mai 2 15:15 /usr/local/gimp-2.4.5/share/gimp/2.0/scripts/script-fu.init -rw-r--r-- 1 root root 2311 mai 2 15:15 /usr/local/gimp-2.4.5/share/gimp/2.0/scripts/script-fu-set-cmap.scm -rw-r--r-- 1 root root 1288 mai 2 15:15 /usr/local/gimp-2.4.5/share/gimp/2.0/scripts/script-fu-util.scm -rw-r--r-- 1 root root 52083 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/ar/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 61588 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/bg/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 47027 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/ca/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 45283 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/cs/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 7986 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/da/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 46936 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/de/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 92281 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/dz/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1939 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/el/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 43995 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/en_CA/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44971 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/en_GB/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44512 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/eo/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 47913 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/es/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 14693 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/et/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 45789 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/eu/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 27877 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/fa/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 31547 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/fi/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 47325 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/fr/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1568 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/ga/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44900 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/gl/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 36271 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/gu/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1679 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/he/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 7989 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/hr/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 48046 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/hu/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1324 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/id/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 46245 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/it/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 27608 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/ja/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 74296 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/km/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 47509 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/ko/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44705 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/lt/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 58933 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/mk/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 7885 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/ms/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 6218 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/nb/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 72866 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/ne/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 26029 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/nl/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 2621 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/oc/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 58118 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/pa/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44979 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/pl/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 46948 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/pt_BR/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 8124 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/pt/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1235 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/ro/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 58964 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/ru/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 2839 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/rw/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 26667 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/sk/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 45545 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/sl/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 7952 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/sr at Latn/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 9555 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/sr/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 44552 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/sv/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 5882 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/tr/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 430 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/tt/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 57265 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/uk/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 28806 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/vi/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 29184 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/xh/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 1084 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/yi/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 23284 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/zh_CN/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 root root 17510 mai 2 15:14 /usr/local/gimp-2.4.5/share/locale/zh_TW/LC_MESSAGES/gimp20-script-fu.mo -rw-r--r-- 1 julien users 6665 oct 10 2007 /usr/local/share/gimp/2.0/help/de/gimp-concepts-script-fu.html -rw-r--r-- 1 julien users 13419 oct 10 2007 /usr/local/share/gimp/2.0/help/de/gimp-using-script-fu-tutorial-extending-text-box.html -rw-r--r-- 1 julien users 21417 oct 10 2007 /usr/local/share/gimp/2.0/help/de/gimp-using-script-fu-tutorial-first-script.html -rw-r--r-- 1 julien users 14523 oct 10 2007 /usr/local/share/gimp/2.0/help/de/gimp-using-script-fu-tutorial.html -rw-r--r-- 1 julien users 14561 oct 10 2007 /usr/local/share/gimp/2.0/help/de/gimp-using-script-fu-tutorial-identifier.html -rw-r--r-- 1 julien users 17275 oct 10 2007 /usr/local/share/gimp/2.0/help/de/gimp-using-script-fu-tutorial-lists.html -rw-r--r-- 1 julien users 15532 oct 10 2007 /usr/local/share/gimp/2.0/help/de/gimp-using-script-fu-tutorial-script.html -rw-r--r-- 1 julien users 6146 oct 10 2007 /usr/local/share/gimp/2.0/help/de/gimp-xtns-script-fu.html -rw-r--r-- 1 julien users 4994 oct 10 2007 /usr/local/share/gimp/2.0/help/de/install-script-fu.html -rw-r--r-- 1 julien users 10070 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-add-bevel.html -rw-r--r-- 1 julien users 11653 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-addborder.html -rw-r--r-- 1 julien users 11467 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-carve-it.html -rw-r--r-- 1 julien users 9047 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-coffee-stain.html -rw-r--r-- 1 julien users 11875 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-drop-shadow.html -rw-r--r-- 1 julien users 15495 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-fuzzy-border.html -rw-r--r-- 1 julien users 12346 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-old-photo.html -rw-r--r-- 1 julien users 19036 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-perspective-shadow.html -rw-r--r-- 1 julien users 13633 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-round-corners.html -rw-r--r-- 1 julien users 6943 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-selection-rounded-rectangle.html -rw-r--r-- 1 julien users 9655 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-slide.html -rw-r--r-- 1 julien users 11685 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-tile-blur.html -rw-r--r-- 1 julien users 13086 oct 10 2007 /usr/local/share/gimp/2.0/help/de/script-fu-xach-effect.html -rw-r--r-- 1 julien users 12593 oct 10 2007 /usr/local/share/gimp/2.0/help/de/standalone-script-fu.html -rw-r--r-- 1 julien users 5799 oct 10 2007 /usr/local/share/gimp/2.0/help/en/gimp-concepts-script-fu.html -rw-r--r-- 1 julien users 12598 oct 10 2007 /usr/local/share/gimp/2.0/help/en/gimp-using-script-fu-tutorial-extending-text-box.html -rw-r--r-- 1 julien users 19524 oct 10 2007 /usr/local/share/gimp/2.0/help/en/gimp-using-script-fu-tutorial-first-script.html -rw-r--r-- 1 julien users 13094 oct 10 2007 /usr/local/share/gimp/2.0/help/en/gimp-using-script-fu-tutorial.html -rw-r--r-- 1 julien users 13097 oct 10 2007 /usr/local/share/gimp/2.0/help/en/gimp-using-script-fu-tutorial-identifier.html -rw-r--r-- 1 julien users 15660 oct 10 2007 /usr/local/share/gimp/2.0/help/en/gimp-using-script-fu-tutorial-lists.html -rw-r--r-- 1 julien users 13994 oct 10 2007 /usr/local/share/gimp/2.0/help/en/gimp-using-script-fu-tutorial-script.html -rw-r--r-- 1 julien users 6034 oct 10 2007 /usr/local/share/gimp/2.0/help/en/gimp-xtns-script-fu.html -rw-r--r-- 1 julien users 4933 oct 10 2007 /usr/local/share/gimp/2.0/help/en/install-script-fu.html -rw-r--r-- 1 julien users 9510 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-add-bevel.html -rw-r--r-- 1 julien users 10535 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-addborder.html -rw-r--r-- 1 julien users 10781 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-carve-it.html -rw-r--r-- 1 julien users 8684 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-coffee-stain.html -rw-r--r-- 1 julien users 11359 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-drop-shadow.html -rw-r--r-- 1 julien users 14761 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-fuzzy-border.html -rw-r--r-- 1 julien users 11610 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-old-photo.html -rw-r--r-- 1 julien users 17908 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-perspective-shadow.html -rw-r--r-- 1 julien users 13030 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-round-corners.html -rw-r--r-- 1 julien users 7233 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-selection-rounded-rectangle.html -rw-r--r-- 1 julien users 9296 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-slide.html -rw-r--r-- 1 julien users 9897 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-tile-blur.html -rw-r--r-- 1 julien users 12442 oct 10 2007 /usr/local/share/gimp/2.0/help/en/script-fu-xach-effect.html -rw-r--r-- 1 julien users 11687 oct 10 2007 /usr/local/share/gimp/2.0/help/en/standalone-script-fu.html -rw-r--r-- 1 julien users 6536 oct 10 2007 /usr/local/share/gimp/2.0/help/es/gimp-concepts-script-fu.html -rw-r--r-- 1 julien users 12664 oct 10 2007 /usr/local/share/gimp/2.0/help/es/gimp-using-script-fu-tutorial-extending-text-box.html -rw-r--r-- 1 julien users 20356 oct 10 2007 /usr/local/share/gimp/2.0/help/es/gimp-using-script-fu-tutorial-first-script.html -rw-r--r-- 1 julien users 13962 oct 10 2007 /usr/local/share/gimp/2.0/help/es/gimp-using-script-fu-tutorial.html -rw-r--r-- 1 julien users 13120 oct 10 2007 /usr/local/share/gimp/2.0/help/es/gimp-using-script-fu-tutorial-identifier.html -rw-r--r-- 1 julien users 15817 oct 10 2007 /usr/local/share/gimp/2.0/help/es/gimp-using-script-fu-tutorial-lists.html -rw-r--r-- 1 julien users 14517 oct 10 2007 /usr/local/share/gimp/2.0/help/es/gimp-using-script-fu-tutorial-script.html -rw-r--r-- 1 julien users 6062 oct 10 2007 /usr/local/share/gimp/2.0/help/es/gimp-xtns-script-fu.html -rw-r--r-- 1 julien users 4981 oct 10 2007 /usr/local/share/gimp/2.0/help/es/install-script-fu.html -rw-r--r-- 1 julien users 9714 oct 10 2007 /usr/local/share/gimp/2.0/help/es/script-fu-add-bevel.html -rw-r--r-- 1 julien users 10857 oct 10 2007 /usr/local/share/gimp/2.0/help/es/script-fu-addborder.html -rw-r--r-- 1 julien users 11129 oct 10 2007 /usr/local/share/gimp/2.0/help/es/script-fu-carve-it.html -rw-r--r-- 1 julien users 9210 oct 10 2007 /usr/local/share/gimp/2.0/help/es/script-fu-coffee-stain.html -rw-r--r-- 1 julien users 15125 oct 10 2007 /usr/local/share/gimp/2.0/help/es/script-fu-fuzzy-border.html -rw-r--r-- 1 julien users 11832 oct 10 2007 /usr/local/share/gimp/2.0/help/es/script-fu-old-photo.html -rw-r--r-- 1 julien users 13439 oct 10 2007 /usr/local/share/gimp/2.0/help/es/script-fu-round-corners.html -rw-r--r-- 1 julien users 7007 oct 10 2007 /usr/local/share/gimp/2.0/help/es/script-fu-selection-rounded-rectangle.html -rw-r--r-- 1 julien users 9578 oct 10 2007 /usr/local/share/gimp/2.0/help/es/script-fu-slide.html -rw-r--r-- 1 julien users 6587 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/gimp-concepts-script-fu.html -rw-r--r-- 1 julien users 12876 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/gimp-using-script-fu-tutorial-extending-text-box.html -rw-r--r-- 1 julien users 20485 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/gimp-using-script-fu-tutorial-first-script.html -rw-r--r-- 1 julien users 14170 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/gimp-using-script-fu-tutorial.html -rw-r--r-- 1 julien users 13328 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/gimp-using-script-fu-tutorial-identifier.html -rw-r--r-- 1 julien users 16009 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/gimp-using-script-fu-tutorial-lists.html -rw-r--r-- 1 julien users 15198 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/gimp-using-script-fu-tutorial-script.html -rw-r--r-- 1 julien users 5916 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/gimp-xtns-script-fu.html -rw-r--r-- 1 julien users 5414 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/install-script-fu.html -rw-r--r-- 1 julien users 10027 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/script-fu-add-bevel.html -rw-r--r-- 1 julien users 11178 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/script-fu-addborder.html -rw-r--r-- 1 julien users 8636 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/script-fu-coffee-stain.html -rw-r--r-- 1 julien users 15113 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/script-fu-fuzzy-border.html -rw-r--r-- 1 julien users 10782 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/script-fu-old-photo.html -rw-r--r-- 1 julien users 13005 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/script-fu-round-corners.html -rw-r--r-- 1 julien users 7092 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/script-fu-selection-rounded-rectangle.html -rw-r--r-- 1 julien users 8461 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/script-fu-slide.html -rw-r--r-- 1 julien users 9648 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/script-fu-tile-blur.html -rw-r--r-- 1 julien users 12007 oct 10 2007 /usr/local/share/gimp/2.0/help/fr/standalone-script-fu.html -rw-r--r-- 1 julien users 6017 oct 10 2007 /usr/local/share/gimp/2.0/help/it/gimp-concepts-script-fu.html -rw-r--r-- 1 julien users 12914 oct 10 2007 /usr/local/share/gimp/2.0/help/it/gimp-using-script-fu-tutorial-extending-text-box.html -rw-r--r-- 1 julien users 19930 oct 10 2007 /usr/local/share/gimp/2.0/help/it/gimp-using-script-fu-tutorial-first-script.html -rw-r--r-- 1 julien users 12935 oct 10 2007 /usr/local/share/gimp/2.0/help/it/gimp-using-script-fu-tutorial.html -rw-r--r-- 1 julien users 13332 oct 10 2007 /usr/local/share/gimp/2.0/help/it/gimp-using-script-fu-tutorial-identifier.html -rw-r--r-- 1 julien users 16110 oct 10 2007 /usr/local/share/gimp/2.0/help/it/gimp-using-script-fu-tutorial-lists.html -rw-r--r-- 1 julien users 14312 oct 10 2007 /usr/local/share/gimp/2.0/help/it/gimp-using-script-fu-tutorial-script.html -rw-r--r-- 1 julien users 5469 oct 10 2007 /usr/local/share/gimp/2.0/help/it/gimp-xtns-script-fu.html -rw-r--r-- 1 julien users 5126 oct 10 2007 /usr/local/share/gimp/2.0/help/it/install-script-fu.html -rw-r--r-- 1 julien users 10094 oct 10 2007 /usr/local/share/gimp/2.0/help/it/script-fu-add-bevel.html -rw-r--r-- 1 julien users 11128 oct 10 2007 /usr/local/share/gimp/2.0/help/it/script-fu-addborder.html -rw-r--r-- 1 julien users 8967 oct 10 2007 /usr/local/share/gimp/2.0/help/it/script-fu-coffee-stain.html -rw-r--r-- 1 julien users 12016 oct 10 2007 /usr/local/share/gimp/2.0/help/it/script-fu-drop-shadow.html -rw-r--r-- 1 julien users 15573 oct 10 2007 /usr/local/share/gimp/2.0/help/it/script-fu-fuzzy-border.html -rw-r--r-- 1 julien users 12142 oct 10 2007 /usr/local/share/gimp/2.0/help/it/script-fu-old-photo.html -rw-r--r-- 1 julien users 13563 oct 10 2007 /usr/local/share/gimp/2.0/help/it/script-fu-round-corners.html -rw-r--r-- 1 julien users 6667 oct 10 2007 /usr/local/share/gimp/2.0/help/it/script-fu-selection-rounded-rectangle.html -rw-r--r-- 1 julien users 9024 oct 10 2007 /usr/local/share/gimp/2.0/help/it/script-fu-tile-blur.html -rw-r--r-- 1 julien users 12220 oct 10 2007 /usr/local/share/gimp/2.0/help/it/standalone-script-fu.html -rw-r--r-- 1 julien users 6593 oct 10 2007 /usr/local/share/gimp/2.0/help/ko/gimp-concepts-script-fu.html -rw-r--r-- 1 julien users 5124 oct 10 2007 /usr/local/share/gimp/2.0/help/ko/install-script-fu.html -rw-r--r-- 1 julien users 11949 oct 10 2007 /usr/local/share/gimp/2.0/help/ko/standalone-script-fu.html -rw-r--r-- 1 julien users 6466 oct 10 2007 /usr/local/share/gimp/2.0/help/no/gimp-concepts-script-fu.html -rw-r--r-- 1 julien users 13104 oct 10 2007 /usr/local/share/gimp/2.0/help/no/gimp-using-script-fu-tutorial-extending-text-box.html -rw-r--r-- 1 julien users 22378 oct 10 2007 /usr/local/share/gimp/2.0/help/no/gimp-using-script-fu-tutorial-first-script.html -rw-r--r-- 1 julien users 13658 oct 10 2007 /usr/local/share/gimp/2.0/help/no/gimp-using-script-fu-tutorial.html -rw-r--r-- 1 julien users 13995 oct 10 2007 /usr/local/share/gimp/2.0/help/no/gimp-using-script-fu-tutorial-identifier.html -rw-r--r-- 1 julien users 17635 oct 10 2007 /usr/local/share/gimp/2.0/help/no/gimp-using-script-fu-tutorial-lists.html -rw-r--r-- 1 julien users 14454 oct 10 2007 /usr/local/share/gimp/2.0/help/no/gimp-using-script-fu-tutorial-script.html -rw-r--r-- 1 julien users 5396 oct 10 2007 /usr/local/share/gimp/2.0/help/no/gimp-xtns-script-fu.html -rw-r--r-- 1 julien users 4876 oct 10 2007 /usr/local/share/gimp/2.0/help/no/install-script-fu.html -rw-r--r-- 1 julien users 6471 oct 10 2007 /usr/local/share/gimp/2.0/help/no/script-fu-selection-rounded-rectangle.html -rw-r--r-- 1 julien users 8940 oct 10 2007 /usr/local/share/gimp/2.0/help/no/script-fu-tile-blur.html -rw-r--r-- 1 julien users 12221 oct 10 2007 /usr/local/share/gimp/2.0/help/no/standalone-script-fu.html -rw-r--r-- 1 julien users 7368 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/gimp-concepts-script-fu.html -rw-r--r-- 1 julien users 5706 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/install-script-fu.html -rw-r--r-- 1 julien users 11003 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/script-fu-add-bevel.html -rw-r--r-- 1 julien users 12301 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/script-fu-addborder.html -rw-r--r-- 1 julien users 9299 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/script-fu-coffee-stain.html -rw-r--r-- 1 julien users 16565 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/script-fu-fuzzy-border.html -rw-r--r-- 1 julien users 12848 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/script-fu-old-photo.html -rw-r--r-- 1 julien users 14452 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/script-fu-round-corners.html -rw-r--r-- 1 julien users 9795 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/script-fu-slide.html -rw-r--r-- 1 julien users 10033 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/script-fu-tile-blur.html -rw-r--r-- 1 julien users 15213 oct 10 2007 /usr/local/share/gimp/2.0/help/ru/standalone-script-fu.html
atb,
Julien
I resolved my problem by deleting the hidden directory /home//.gimp-2.4.
This directory, that contains gimp settings, is not deleted when uninstalling gimp. A new installation uses it. That's interesting if you install a new version, but, if it contains an error, this error persists in all new installations.
GIMP re-creates this directory on starting again.
Julien
That's intentional. You don't want to lose your settings when the system administrator decides that a new version of gimp should be installed.
I don't know exactly what went wrong in your case. But is it possible that your system clock is screwed?
