Gimp
Gimp Karl Faxnas 23 Feb 20:20
  Gimp Axel Wernicke 23 Feb 22:40
  Gimp Roman Joost 25 Feb 08:45
Karl Faxnas
2008-02-23 20:20:22 UTC (about 17 years ago)
Gimp
Hi Gimp-user.
I'm running iMac Leopard and Gimp 2.4.4-XII for abouth 6 months.
I have made some animations , my own and also from Script-Fu.
There is two nasty problem I would like to get solved.
1) Flame-making. I have try 50 times to get trough every step to make those flames, but i dont fix it.
Every step up to " Choose Gradient " run perfectly. but when I try to put the gradient ( Germany flag Smooth) into place. No way. last try, the germand Flag Smooth disappeard from tool-palett. Gone.
Frustrating. look at the Url:< http://gug.sunsite.dk/tutorials/tomcat13/ >
2)
I have learn abouth filemakings. when my projecs are ready, in Gimps own XCF, i give them a name,
example: kallebling.gif -png - or jpeg. Never mind wath I put before ________.gif.
> Save as: kallebling.gif > sending mail to my self attach > file kallebling.gif. I open up the mail, there is the file kallebling.gif, but very dead and gray. No sparkling bling-bling from script-fu as I made from: Follow my step:
> Gimp > Extr > scroll down to Script-fu > Logos > Bling text > I choose Bling stew > ( dont matter)
> aktivate Animate > filter > Animation > Play. and a very nice locking sparkling script-fu animations is infront of me.. But, how to do the rest.
Anyone out ther with any ideas.
Regards
Kalle
Axel Wernicke
2008-02-23 22:40:50 UTC (about 17 years ago)
Gimp
Hi Karl,
this ist not a topic we should discuss in the gimp-docs list. This list is just for the group of document writers and readers. Your problem is in much better hands over there in the gimp-user list.
Please fasten you seatbelt, I'll forward you...
Greetings, lexA
Am 23.02.2008 um 20:20 schrieb Karl Faxnas:
Hi Gimp-user.
2)
Regards
Kalle
Roman Joost
2008-02-25 08:45:09 UTC (about 17 years ago)
Gimp
Hi Karl,
On Sat, Feb 23, 2008 at 08:20:22PM +0100, Karl Faxnas wrote:
Hi Gimp-user.
There is two nasty problem I would like to get solved. [...]
_______________________________________________ Gimp-docs mailing list
Gimp-docs at lists.XCF.Berkeley.EDU
You're probably posting to the wrong mailing list. This mailing list discusses the development of the GIMP user manual. You need to subscribe to GIMP-user:
https://lists.xcf.berkeley.edu/mailman/listinfo/gimp-user
A list of the available mailing lists can be found on the GIMP homepage:
http://www.gimp.org/mail_lists.html
Cheers,
