stylesheets/htmlalternate.xsl
stylesheets/htmlalternate.xsl Vitaly Lomov 27 Nov 18:03
  stylesheets/htmlalternate.xsl Sven Neumann 27 Nov 18:33
   stylesheets/htmlalternate.xsl Ulf-D. Ehlert 28 Nov 12:28
    stylesheets/htmlalternate.xsl Sven Neumann 28 Nov 20:00
Vitaly Lomov
2007-11-27 18:03:27 UTC (about 17 years ago)
As I was about to commit (rev 2202) I noticed that the file stylesheets/htmlalternate.xsl was marked with ? in svn status. I don't know what it does, I just added as part of my commit. Btw, I tried adding it to .cvsignore to exclude it from commit, but that didn't work.
2007-11-27 18:33:47 UTC (about 17 years ago)
What is this file? It seems to be generated, thus you should not have added it to SVN. It appears to be generated from stylesheets/htmlalternate.xsl.in, but I don't see anything in it that would have to be substituted by configure, so why is the file generated at all?
You didn't have to do anything to exclude the file from commit. Unless you explicitely add the file, it is not committed.
The user manual isn't kept in CVS any longer. The .cvsignore files don't have any meaning in a Subversion repository and should all be removed. In order to tell Subversion that a certain file should be ignored,as you used to do with .cvsignore, you need to edit the svn:ignore property of the directory that holds the file. See http://svnbook.red-bean.com/en/1.2/svn-book.html#svn.advanced.props.special.ignore
Ulf-D. Ehlert
2007-11-28 12:28:26 UTC (about 17 years ago)
Sven Neumann (Dienstag, 27. November 2007, 18:33):
It's a member of AC_CONFIG_FILES, otherwise "make distcheck" didn't work (it wasn't copied to the directory $(distdir)/_build).
Is there a better way to make "make" work?
Ulf -------------- next part -------------- A non-text attachment was scrubbed... Name: not available
Desc: not available
Url : /lists/gimp-docs/attachments/20071128/e642456d/attachment.bin
2007-11-28 20:00:55 UTC (about 17 years ago)
You could add a makefile rule that copies it to the build directory.
If you don't want to do that, then stick to the current hack. But please remove the generated file from SVN and edit the svn:ignore property so that it doesn't show up on 'svn status'. If you need help, let me know.
Oh, and someone should remove all the .cvsignore files before they cause more confusion.
