Key references
Key references julien 18 Jul 07:05
  Key references Axel Wernicke 18 Jul 07:36
julien
2007-07-18 07:05:36 UTC (almost 18 years ago)
Key references
po files are translated for de fr it... but key-reference.xml is built for 'en' only
and the key references don't appear in html index.
I translated key-reference.xml and saved it as key-reference-fr.xml. I added a
Key references are stable. Why build key-reference.xml every time? May I commit key-reference-fr?
Julien
Axel Wernicke
2007-07-18 07:36:07 UTC (almost 18 years ago)
Key references
I don't see that the key reference makes any sens in the manual itself - at least not as simple list. I'd suggest we focus on the external short reference first and may be we can this one include in the manual as appendix later?!
Greetings, lexA
2007/7/18, julien :
Julien
_______________________________________________ Gimp-docs mailing list
Gimp-docs at lists.XCF.Berkeley.EDU
