concepts/paths.xml
concepts/paths.xml julien 18 Apr 08:15
  concepts/paths.xml Axel Wernicke 18 Apr 08:22
   concepts/paths.xml Michael Schumacher 18 Apr 11:33
  concepts/paths.xml Axel Wernicke 18 Apr 08:26
   concepts/paths.xml julien 18 Apr 14:33
julien
2007-04-18 08:15:58 UTC (about 18 years ago)
concepts/paths.xml
concepts/paths.xml disappeared from repository. I can't find when this happened in Changelog. Any reason for this? I am not sure I can restaure it with a svn add. I hesitate.
Greetings
Julien
Axel Wernicke
2007-04-18 08:22:29 UTC (about 18 years ago)
concepts/paths.xml
Hi Julien,
since we are putting concepts and usage much tighter together now, you can find the following line in the using/path.xml:
2007-03-24 lexa: merged path concept and path usage
So, whatever you wanted to do, do it in the using/path.xml
Greetings, lexA
Am 18.04.2007 um 08:15 schrieb julien:
Greetings
Julien
Axel Wernicke
2007-04-18 08:26:30 UTC (about 18 years ago)
concepts/paths.xml
btw. there is a changelog entry:
2007-03-25 Axel Wernicke
* src/using/fileformats.xml * src/using/paths.xml
* src/gimp.xml
* src/concepts/paths.xml
* images/using/save-tiff-dialog.png * images/using/text-example.png
* images/using/path-stroking-examples.png * images/using/path-text-stroked.png * images/using/path-examples.png
* images/using/path-with-anchors.png * images/using/path-from-text.png: merged path-using and path-concept
Greetings
Julien
2007-04-18 11:33:08 UTC (about 18 years ago)
concepts/paths.xml
Von: Axel Wernicke
Hi Julien,
Maybe you should list the affected files explicitly, like in the GIMP ChangeLog.
HTH, Michael
julien
2007-04-18 14:33:58 UTC (about 18 years ago)
concepts/paths.xml
Because I was working on concepts/paths.xml, this file was not deleted on update and created problems in the diff...
'svn status' displays M, A, D... Why we don't use this information in Changelog, instead of that blank '*'. ?
Commit would be simpler, since the text editor offers the svn status display.
Julien
