unreferenced images
unreferenced images Axel Wernicke 09 Jul 11:41
  unreferenced images Roman Joost 01 Aug 23:50
Axel Wernicke
2006-07-09 11:41:25 UTC (almost 19 years ago)
unreferenced images
Hi folks,
today I checked the usage of images in the manual using Romans validation script. Good news is, that currently all image files which are referenced from the xml files exist. But on the other hand there are dozens of images file which are not referenced in the manuals xml files at all. This means they are not more that a waste of space right now. I'd encourage everybody to check the images for your language, whether reference them or remove them from the cvs. I'd suggest that we give ourself a four week period to fix this before removing unreferenced images from the repository.
Greetings, lexA
this is the list of unreferenced image files:
./images/dialogs/dialogs-configure-grid.png ./images/dialogs/dialogs-documents-grid.png ./images/dialogs/dialogs-documents-menu.png ./images/dialogs/dialogs-documents.png ./images/dialogs/dialogs-error-console.png ./images/dialogs/dialogs-layer-menu.png ./images/dialogs/dialogs-menus-imagewindow-file-new.png ./images/dialogs/dialogs-templates-menu.png ./images/dialogs/dialogs-view-infowindow.png ./images/dialogs/stock-menu-left-12.png ./images/dialogs/cs/dialogs-templates-menu.png ./images/dialogs/fr/dialogs-brushes.png ./images/dialogs/fr/dialogs-channels-quickmask.png ./images/dialogs/fr/dialogs-histogram-menu.png ./images/dialogs/it/color-dialog.png ./images/dialogs/it/dialogs-channel-masks-gradient.png ./images/dialogs/it/dialogs-channel-masks.png ./images/dialogs/it/dialogs-channel-quickmask.png ./images/dialogs/it/dialogs-gradient.png ./images/dialogs/no/dialog-highlight-dockbar.png ./images/dialogs/no/dialog-highlight-handle.png ./images/dialogs/no/dialog-highlight-imagemenu.png ./images/dialogs/no/dialog-highlight-tabmenu.png ./images/dialogs/no/dialogs-channels-example.png ./images/dialogs/no/dialogs-indexed-palette.png ./images/dialogs/no/dialogs-palette-editor.png ./images/dialogs/no/dialogs-palettes.png ./images/dialogs/no/file-gih-save.png ./images/dialogs/no/standard-setup.png ./images/dialogs/no/tab-menu-preview-size.png ./images/dialogs/no/tab-menu-tab-style.png ./images/dialogs/no/tab-menu.png
./images/dialogs/ru/color-dialog_cmyk.png ./images/dialogs/ru/color-dialog_scale.png ./images/dialogs/ru/color-dialog_triangle.png ./images/dialogs/ru/color-dialog_water_colour.png ./images/dialogs/ru/dialogs-brushes-menu.png ./images/dialogs/ru/dialogs-channel-masks.png ./images/dialogs/ru/dialogs-channel-quickmask.png ./images/dialogs/ru/dialogs-configure-grid.png ./images/dialogs/ru/dialogs-documents-grid.png ./images/dialogs/ru/dialogs-documents-menu.png ./images/dialogs/ru/dialogs-documents.png ./images/dialogs/ru/dialogs-error-console.png ./images/dialogs/ru/dialogs-file-open-advanced.png ./images/dialogs/ru/dialogs-file-open.png ./images/dialogs/ru/dialogs-file-save-advanced-full.png ./images/dialogs/ru/dialogs-file-save-advanced.png ./images/dialogs/ru/dialogs-file-save.png ./images/dialogs/ru/dialogs-fonts-menu.png ./images/dialogs/ru/dialogs-gradient-editor.png ./images/dialogs/ru/dialogs-gradient-editor_p1.png ./images/dialogs/ru/dialogs-gradient-editor_p2.png ./images/dialogs/ru/dialogs-gradient-editor_p3.png ./images/dialogs/ru/dialogs-gradient.png ./images/dialogs/ru/dialogs-image-canvas-size.png ./images/dialogs/ru/dialogs-image-configure-grid.png ./images/dialogs/ru/dialogs-image-merge-visible.png ./images/dialogs/ru/dialogs-image-mode-indexed.png ./images/dialogs/ru/dialogs-image-scale-image.png ./images/dialogs/ru/dialogs-layer-menu.png ./images/dialogs/ru/dialogs-layer-opacity.png ./images/dialogs/ru/dialogs-layer-rename.png ./images/dialogs/ru/dialogs-menus-imagewindow-edit-stroke.png ./images/dialogs/ru/dialogs-menus-imagewindow-file-new.png ./images/dialogs/ru/dialogs-new-image-advanced.png ./images/dialogs/ru/dialogs-new-image-colorspace.png ./images/dialogs/ru/dialogs-new-image-fill.png ./images/dialogs/ru/dialogs-new-image-templates.png ./images/dialogs/ru/dialogs-new-image.png ./images/dialogs/ru/dialogs-new-layer.png ./images/dialogs/ru/dialogs-palette-import.png ./images/dialogs/ru/dialogs-paths-rename.png ./images/dialogs/ru/dialogs-patterns-list.png ./images/dialogs/ru/dialogs-patterns.png ./images/dialogs/ru/dialogs-templates-menu.png ./images/dialogs/ru/dialogs-templates.png ./images/dialogs/ru/dialogs-tool-options-rect-select.png ./images/dialogs/ru/dialogs-undo-history.png ./images/dialogs/ru/dialogs-view-infowindow-com.png ./images/dialogs/ru/dialogs-view-infowindow-curs.png ./images/dialogs/ru/dialogs-view-infowindow-gen.png ./images/dialogs/ru/dialogs-view-infowindow.png ./images/filters/filters-alienmap1-figures.png ./images/filters/filters-artistic-gimpressionist-orientmap.png ./images/filters/filters-artistic-gimpressionist-sizemap.png ./images/filters/filters-artistic-gimpressionist.png ./images/filters/filters-blur-blur.png ./images/filters/filters-blur-gaussIIR.png ./images/filters/filters-blur-gaussRLE.png ./images/filters/filters-color-colortoalpha.png ./images/filters/filters-render-checkerboard.png ./images/filters/filters-render-cmlexplorer.png ./images/filters/options-artistic-gimpressionist8.png ./images/filters/examples/color-taj-retinex.jpg ./images/filters/examples/distort-taj-engrave.jpg ./images/filters/examples/vpropag7.png ./images/filters/ru/filters-artistic-applycanvas.png ./images/filters/ru/filters-artistic-cubism.png ./images/filters/ru/filters-artistic-gimpressionist-orientmap.png ./images/filters/ru/filters-artistic-gimpressionist-sizemap.png ./images/filters/ru/filters-artistic-gimpressionist.png ./images/filters/ru/filters-artistic-oilify.png ./images/filters/ru/filters-blur-blur.png ./images/filters/ru/filters-blur-gaussIIR.png ./images/filters/ru/filters-blur-gaussRLE.png ./images/filters/ru/filters-blur-gaussselect.png ./images/filters/ru/filters-blur-mblur.png ./images/filters/ru/filters-blur-pixelize.png ./images/filters/ru/filters-blur-tileable.png ./images/filters/ru/filters-color-borderaverage.png ./images/filters/ru/filters-color-ccanalysis.png ./images/filters/ru/filters-color-channelmixer.png ./images/filters/ru/filters-color-colorify.png ./images/filters/ru/filters-color-colortoalpha.png ./images/filters/ru/filters-color-compose.png ./images/filters/ru/filters-color-decompose.png ./images/math/dot-for-dot.png
./images/menus/display-filters-contrast.png ./images/menus/display-filters-vision.png ./images/menus/image-scale.png
./images/menus/menus-dialogs.png
./images/menus/menus-file-open-recent.png ./images/menus/menus-script-fu.png
./images/menus/menus-view-padding-color.png ./images/menus/threshold-alpha-dialog.png ./images/preferences/prefs-input-controllers-wheel.png ./images/preferences/prefs-monitor.png ./images/preferences/prefs-session.png ./images/preferences/fr/prefs-input-controllers-wheel.png ./images/preferences/nl/prefs-default-grid.png ./images/preferences/nl/prefs-display.png ./images/preferences/nl/prefs-environment.png ./images/preferences/nl/prefs-folders-brush.png ./images/preferences/nl/prefs-folders.png ./images/preferences/nl/prefs-help.png ./images/preferences/nl/prefs-image-window-appearance.png ./images/preferences/nl/prefs-image-window-title.png ./images/preferences/nl/prefs-image-window.png ./images/preferences/nl/prefs-input-controllers.png ./images/preferences/nl/prefs-input-devices.png ./images/preferences/nl/prefs-interface.png ./images/preferences/nl/prefs-monitor.png ./images/preferences/nl/prefs-new-image.png ./images/preferences/nl/prefs-theme.png ./images/preferences/nl/prefs-tool-options.png ./images/preferences/nl/prefs-window-management.png ./images/preferences/ru/prefs-default-grid.png ./images/preferences/ru/prefs-display.png ./images/preferences/ru/prefs-environment.png ./images/preferences/ru/prefs-folder.png ./images/preferences/ru/prefs-folders-brush.png ./images/preferences/ru/prefs-help.png ./images/preferences/ru/prefs-image-window-appearance.png ./images/preferences/ru/prefs-image-window-title.png ./images/preferences/ru/prefs-image-window.png ./images/preferences/ru/prefs-interface.png ./images/preferences/ru/prefs-list.png ./images/preferences/ru/prefs-new-image.png ./images/preferences/ru/prefs-theme.png ./images/preferences/ru/prefs-tool-options.png ./images/preferences/ru/prefs-toolbox.png ./images/preferences/ru/prefs-window-managment.png ./images/tool-options/brush-browser.png ./images/tool-options/fade-out.png
./images/tool-options/gradient-nooffset.png ./images/tool-options/gradient-offset.png ./images/tool-options/gradient.png
./images/tool-options/hard-edge-off.png ./images/tool-options/hard-edge-on.png ./images/toolbox/bpg.png
./images/toolbox/palette.png
./images/toolbox/tool-options-path.png ./images/toolbox/toolbox.png
./images/toolbox/tools-histogram.png ./images/toolbox/cs/toolbox-blur.png ./images/toolbox/cs/toolbox-clone.png ./images/toolbox/cs/toolbox-crop.png ./images/toolbox/cs/toolbox-dodge.png ./images/toolbox/cs/toolbox-ellipsel.png ./images/toolbox/cs/toolbox-fill.png ./images/toolbox/cs/toolbox-flip.png ./images/toolbox/cs/toolbox-lasso.png ./images/toolbox/cs/toolbox-move.png ./images/toolbox/cs/toolbox-palette.png ./images/toolbox/cs/toolbox-path.png ./images/toolbox/cs/toolbox-pencil.png ./images/toolbox/cs/toolbox-perspective.png ./images/toolbox/cs/toolbox-rectsel.png ./images/toolbox/cs/toolbox-scale.png ./images/toolbox/cs/toolbox-selbycolor.png ./images/toolbox/cs/toolbox-shear.png ./images/toolbox/cs/toolbox-smudge.png ./images/toolbox/cs/toolbox-text.png ./images/toolbox/cs/toolbox-zoom.png ./images/toolbox/cs/toolbox.png
./images/toolbox/no/tool-dialog-text.png ./images/using/file-save-dialog-basic.png ./images/using/file-save-dialog-browse.png ./images/using/imagewindow-quickmask.png ./images/using/ui-monitor.png
./images/using/it/ui-log.png
./images/using/it/ui-performance.png ./images/using/it/ui-personal.png
./images/using/it/ui-welcome.png
./images/using/nl/file-gih-save.png
./images/using/no/correlation.png
./images/using/zh_CN/file-save-dialog-basic.png
- --- Live is like a chocolate box, you never know what you wanna get... GPG Signatur auf http://wernicke-online.net/Impressum/ pr?fen
-----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.1 (Darwin)
iD8DBQFEsU3QR9mXLVsAbiQRArFFAJ4o40fxg1+9RHi+vpHMZ8TuTfXrfgCeO6A+ jxlb/oP2gZ4xVF7cGqMFLcA=
=eeR3
-----END PGP SIGNATURE-----
Roman Joost
2006-08-01 23:50:08 UTC (over 18 years ago)
unreferenced images
Hi Axel,
Greetings, lexA
this is the list of unreferenced image files: [...] list
Well, if nobody removed some of the unused files yet, you're very welcome to do so.
At least they'll be removed before a new gimp-help release.
Greetings,
