make validate
7 of 7 messages available
make validate julien 21 Mar 11:46
  make validate Axel Wernicke 21 Mar 12:08
   make validate julien 21 Mar 12:33
    make validate Roman Joost 21 Mar 23:58
     make validate julien 22 Mar 11:35
      make validate Roman Joost 23 Mar 00:07
      make validate Sven Neumann 23 Mar 00:27
julien
2006-03-21 11:46:43 UTC (about 19 years ago)
make validate
Formerly, when I typed "make validate", validation was for all languages. Now, it is for "fr" only. I prefer the former version.
Is it possible to return to it?
Here is my configure.in:
# You can set the ALL_LINGUAS environment variable to # control what languages are build.
if test "x$ALL_LINGUAS" != "x"; then ALL_LINGUAS=$ALL_LINGUAS
else
ALL_LINGUAS="cs de en fr hr it nl sv zh_CN" fi
AC_SUBST(ALL_LINGUAS)
julien
Axel Wernicke
2006-03-21 12:08:29 UTC (about 19 years ago)
make validate
Am 21.03.2006 um 20:46 schrieb julien:
that was not changed - was it??
for a good reason!
else
hmm, so what happens if you say make validate ALL_LINGUAS="en cs de fr" ? Does it work? Did you set the ALL_LINGUAS variable in your shell (by accident may be)?
just wondering...
greetings, lexA
julien
julien
2006-03-21 12:33:11 UTC (about 19 years ago)
make validate
If I type "make validate ALL_LINGUAS="en de fr", that works right. If I type "make validate", I get fr only.
With "set", I get a list of variables, but ALL_LINGUAS is not in it...
julien
Axel Wernicke a ?crit :
for a good reason!
else
just wondering...
greetings, lexA
julien
Roman Joost
2006-03-21 23:58:13 UTC (about 19 years ago)
make validate
Is it possible that your terminal remembers settings? You may try:
unset ALL_LINGUAS
to set any variables you exported.
Greetings,
julien
2006-03-22 11:35:16 UTC (about 19 years ago)
make validate
Unfortunately, 'unset ALL_LINGUAS' changes nothing... 'make validate' was working well before. This problem appeared suddenly. I use Linux only, actually, to work with CVS. Too many problems with Linux.
Greetings
julien
Roman Joost a ?crit :
unset ALL_LINGUAS
Greetings,
Roman Joost
2006-03-23 00:07:35 UTC (about 19 years ago)
make validate
Hm... do you still work as root or as a normal user? If you switch between them, you probably have the variable set for a different user?
Greetings,
2006-03-23 00:27:58 UTC (about 19 years ago)
make validate
julien writes:
What matters is what ALL_LINGUAS was set to when you last run the configure script. Unsetting it and only running make is not going to change anything.
