./configure fatal warning
9 of 9 messages available
make check Florent Monnier 04 Jan 21:33
make check Sven Neumann 07 Jan 15:53
make check Florent Monnier 07 Jan 21:36
make check Sven Neumann 08 Jan 15:44
make check Florent Monnier 09 Jan 11:37
make check Sven Neumann 09 Jan 14:11
./configure fatal warning Florent Monnier 11 Jan 08:55
./configure fatal warning Sven Neumann 11 Jan 14:23
./configure fatal warning Sven Neumann 11 Jan 14:38
Florent Monnier
2006-01-04 21:33:38 UTC (over 19 years ago)
make check
make check doesn't seems to work:
2006-01-07 15:53:54 UTC (over 19 years ago)
make check
Florent Monnier writes:
Florent Monnier
2006-01-07 21:36:34 UTC (over 19 years ago)
make check
$ make check
make[1]: *** No rule to make target `../tools/testsuite/libtestsuite.la', needed by `testgegl'. Stop.
Seems to work fine for me. I wonder what you are doing wrong. Can you give some more details on how you are building gegl?
$ export CVSROOT=':pserver:anonymous-P2Or9IAOnEWsMpBzKsEm7Ni2O/JbrIOy@public.gmane.org:/cvs/gnome' $ cvs login
$ cvs -z3 checkout gegl
$ cd gegl
$ ./autogen.sh
$ make
2006-01-08 15:44:02 UTC (over 19 years ago)
make check
$ make check
$ cd gegl
$ ./autogen.sh
$ make
configure completes successfully?
Florent Monnier
2006-01-09 11:37:32 UTC (over 19 years ago)
make check
$ make check
$ cd gegl
$ ./autogen.sh
$ make
Today 'make check' works.
The Makefile is created, there is a warning though: (I'm using a Mandriva 2006 RC2)
2006-01-09 14:11:53 UTC (over 19 years ago)
make check
Florent Monnier
2006-01-11 08:55:57 UTC (over 19 years ago)
$ ./autogen.sh
WARNING: aclocal's directory is /usr/share/aclocal, but... no file /usr/share/aclocal/intltool.m4 You may see fatal macro warnings below. If these files are installed in /some/dir, set the ACLOCAL_FLAGS environment variable to "-I /some/dir", or install /usr/share/aclocal/intltool.m4.
This warning is fatal and must not be ignored. Please fix your build environment.
How could I fix my build environment for this? Where should I search for intltool.m4? Or where could I get it?
2006-01-11 14:23:32 UTC (over 19 years ago)
$ ./autogen.sh
intltool.m4 is distributed with intltool. Perhaps you want to read the aclocal and automake documentation to understand the purpose of these m4 files and what exactly aclocal is doing. But in general you shouldn't have to worry about this if intltool is installed by whatever package manager your distribution is using. If you installed it manually, you will have to set ACLOCAL_FLAGS as explained in the warning (see above).
2006-01-11 14:38:32 UTC (over 19 years ago)
I just figured that we are not currently doing any internationalization. So intltool and glib-gettextize are actually not needed at the moment. I have changed autogen.sh accordingly.
