Need Some Help with a Really Bad Scanner
Need Some Help with a Really Bad Scanner Philbeaux 17 Dec 15:46
  Need Some Help with a Really Bad Scanner SimoneRodriguez 21 May 11:35
   Need Some Help with a Really Bad Scanner Philbeaux 21 May 11:48
2018-12-17 15:46:46 UTC (over 6 years ago)
I won't go into the details but the bottom line is I'm stuck using a really bad scanner for images.
http://nflpastplayers.com/wp-content/uploads/2018/12/hornung.jpg
http://nflpastplayers.com/wp-content/uploads/2018/12/del-shofner.jpg
I really don't even know where to start to fix them. Some tips would be nice but if someone could point me to some resources and/or tutorials -- preferably on a beginner or novice levei -- it would be very much appreciated.
2019-05-21 11:35:14 UTC (almost 6 years ago)
I see... So what is the main aspect you need in the scanner? Just to scan or anything additional also?
2019-05-21 11:48:16 UTC (almost 6 years ago)
Well, I guess what I need is for it to scan decent images. The scan results are horrible and unusable, as far as I'm concerned.
As I posted this a while back I've been able to do a little research and ask the same question at a few other places and I've come to the conclusion that this scanner just is not a good image scanner. It's designed for document scanning - which it does great at. But for images, not go great.
