Text quality in gimp.
        Yes, you are missing something. Partly having to forget PhotoShop practices.
In Gimp however, it seems like the text is automatically rasterized.
The problem comes in when i want to resize the text.
Providing you keep your image (save it) in Gimp .xcf format, a text layer remains a text layer. That is one that shows a big 'T' in the layer dialogue.  It is rasterized by applying some sort of transform, shear for example. Even then it is possible to return to a 'T' text layer, however all formatting is discarded.
If i try using the transform tool to resize text the quality
of the text degrades tremendously.
I Basically have to retype at a larger size.
Is this really how gimp is or am i just missing something?
Do not use the transform tool.
With the text layer active and using the text tool (1) as in screenshot
All the text can be changed in one go, size, font, colour, using the text tool options (2)
Part of the text can be changed by selecting the part required and using the on-canvas dialogue. (3)
a demo, a bit old but at least I kept it short
http://www.youtube.com/watch?v=ChcTE9KROmc&hd=1
