Correcting Curved Building Edge
Correcting Curved Building Edge mockfrog 27 Mar 02:42
  Correcting Curved Building Edge rich2005 27 Mar 10:38
   Correcting Curved Building Edge mockfrog 28 Mar 06:27
2017-03-27 02:42:03 UTC (about 8 years ago)
I have a photo of a building.
The right edge (wall) is slightly curved and I want it straightened out.
I used Perspective Tool to fix the slight perspective error.
See attached image
I am using Gimp 2.8.6 for Mac OSX
Thanks
Matt
2017-03-27 10:38:57 UTC (about 8 years ago)
See attached image
Thanks
Matt
Well, top of the fascia is not quite level and the canopy definitely is not. Do you really want to try and un-bend that edge.
You could try some alternative thinking to un-bending. Clone the brickwork edge using a selection to constrain the clone tool.
A quick stab attached.
2017-03-28 06:27:55 UTC (about 8 years ago)
Hi Rich
Great suggestion re cloning. I will give that a go.
cheers
Matt
