Need High Def Text
Need High Def Text SportStar 07 Dec 12:29
  Need High Def Text rich2005 08 Dec 11:28
   Need High Def Text SportStar 12 Dec 10:14
  Need High Def Text Alexandre Prokoudine 08 Dec 20:42
   Need High Def Text Steve Kinney 08 Dec 21:09
2016-12-07 12:29:13 UTC (over 8 years ago)
Need High Def Text
Hi, I am using Gimp 2.8 to design an A1 poster. The poster contains text and while it looks OK in 100% or 200%, the moment I go to 400% it all gets pixelated. I have read some info and checked that the text tool is set to Hinting - Full and Antialiasing is ticked.
How can I solve this problem ?
Thanks
2016-12-08 11:28:19 UTC (over 8 years ago)
Need High Def Text
Thanks
Your "A1" poster is tiny. A1 size is 594 mm x 841 mm and your image size in pixels is 592 x 561 pix so I conclude that, apart from the aspect ratio, you have pixels and mm mixed up. Printing that on A1 papergives a resolution of pixels per inch (ppi)
For a poster that will be viewed at a distance you do not need phot-grapic quality 300 ppi but you do need better than 25 ppi, say 150 ppi.
Make a new canvas, Image -> New, in the advanced section set the horizontal/vertical resolution, set the size in mm. After that work in pixels, Gimp is a raster editor, works with pixels.
Then there is the outlining: guessing you did some sort of selection and used that, leaving semi-transparent pixels between the white text and the magenta outline.
A better way once you have a text layer is Text to path -> Stroke the path. Apply that to a layer under the text for best results.
example attached.
2016-12-08 20:42:17 UTC (over 8 years ago)
Need High Def Text
The point of bitmap graphics is that it's all pixels, not vectors.
Alex
2016-12-08 21:09:11 UTC (over 8 years ago)
Need High Def Text
When I make "posters" that will contain both image and text content, I usually do the bitmap content in the GIMP, export the result as PNG, and import it into an new Inkscape file. I do the text and any "line art" as required in Inkscape. The result is a hybrid bitmap/vector image that scales up very well; there will be some loss of resolution in the bitmap content, but text and other vector content will render "perfectly" at any scale when exported as a bitmap file (png or etc.).
Export the Inkscape .svg to PDF with text converted to vectors for reliable printing.
"Just use Inkscape for the text" is not a great answer, since it does involve getting and learning how to use a whole 'nother program if you have not already done so. But if you will be doing similar work in the future, it's well worth the trouble.
:o)
2016-12-12 10:14:05 UTC (over 8 years ago)
Need High Def Text
example attached.
MANY THANKS FOR THE ADVICE
