severe blue cast or mask fix
severe blue cast or mask fix WoodGoat 03 Mar 22:42
  severe blue cast or mask fix Seloquin 18 Apr 10:09
2014-03-03 22:42:47 UTC (about 11 years ago)
Hello:
I'm a newbie Gimp user and not a photographer. I use the Gimp for repair and cleaning up family photos and like to learn on images I've found online.
I'm a huge fan of a singer that passed away in the late '60's and found a photo of her that has such an intense blue cast I have been completely unable to fix it. I've tried everything that I have run across in tutorials and even things I thought might work and no soap.
I've added the image so everyone can see it; the best I've come up with is desaturating and leaving it in grayscale, not what I'd really like, I'd love to have this image in color- not blue!
Cheers and thanks
2015-04-18 10:09:09 UTC (almost 10 years ago)
well spent a moment having a play around with the image, see what i could do, best results where much better than original image.
Colours > Retinex (Level; High) can play around with the bars if you want. >
Colours > map > Sample Colourize > get samples > 0/ 2.34/ 200 will remove most of the blue
duplicate layer > desaturate > Illuminisoty > make sure layers at top > set layer mode to hardlight > New from visable.
create a selection of the hair where its all pinky > colour > hue saturation >
turn red and magenta's > lightness -100 > saturation -100
repeat Hue saturation until hair is black.
Alternatively you can de-saturate, create selection regions and colourise the areas.
