1.3.17 make problem on slackware-9 (current)
1.3.17 make problem on slackware-9 (current) thurgood marshall 05 Aug 15:09
  1.3.17 make problem on slackware-9 (current) Sven Neumann 05 Aug 15:14
thurgood marshall
2003-08-05 15:09:46 UTC (over 21 years ago)
Building gimp on slackware-current, I get the following failure: gimptext-vectors.c: In function `gimp_text_render_vectors': gimptext-vectors.c:265: `FT_GLYPH_FORMAT_OUTLINE' undeclared (first use in this function)
gimptext-vectors.c:265: (Each undeclared identifier is reported only once
gimptext-vectors.c:265: for each function it appears in.) make[3]: *** [gimptext-vectors.o] Error 1 gimp-1.3.16 built OK, though.
Has anybody seen this problem?
What did you do to solve it?
Thanks.
Note: I'm guessing this is a freetype version issue. I have downloaded freetype 2.1.4, but I'm concerned I might hose my X fonts if I install it. XFree86-4.3.0 in slackware has freetype-2 built in.
If this is the problem, then I will have to upgrade freetype and possibly rebuild X, but I don't want to do this unless it's indicated.
Again, thanks for any help, and thanks to the developers--gimp kicks butt!
I think XFree86-4.3.0 comes with freetype 2.1.3, but I'm not sure.
__________________
2003-08-05 15:14:42 UTC (over 21 years ago)
"thurgood marshall" writes:
http://bugzilla.gnome.org/show_bug.cgi?id=118066
