yet another problem in compiling
3 of 4 messages available
yet another problem in compiling bright.1@virgin.net 02 Aug 15:35
yet another problem in compiling Tom Williams 02 Aug 17:17
20030802175403.0974a267.r.o... 07 Oct 20:15
  yet another problem in compiling bright.1@virgin.net 02 Aug 21:21
bright.1@virgin.net
2003-08-02 15:35:53 UTC (over 21 years ago)
i am trying to recompile gimp-1.2.5.tar.gz, as I had to wipe the system.
I have spent all morning downloading and installing everything, that I can gather from the install script, that is required.
I still get this at the end of the 'make' part.
/usr//bin/ld: cannot find -lslang collect2: ld returned 1 exit status
make[3]: *** [aa] Error 1
make[3]: Leaving directory `/home/david/gimp-1.2.5/plug-ins/common' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/home/david/gimp-1.2.5/plug-ins' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/david/gimp-1.2.5' make: *** [all-recursive-am] Error 2
I've looked at rpmfind for this 'lslang' but no clues are given. I've tried a general search using google, with the clue that it may have something to do with mpeg. Nothing definite though.
As far as '[aa]' is concerned I have made a point of installing all the rpms. The following shows that there there.
[david@localhost david]$ rpm -q libaa1 libaa1-1.4.0-0.rc5.5mdk
[david@localhost david]$ rpm -q libaa1-devel libaa1-devel-1.4.0-0.rc5.5mdk
[david@localhost david]$ rpm -q libaa1-static-devel libaa1-static-devel-1.4.0-0.rc5.5mdk [david@localhost david]$
And the same for mpeg
[david@localhost david]$ rpm -q libmpeg2dec0-devel libmpeg2dec0-devel-0.3.1-2mdk
[david@localhost david]$ rpm -q libmpeg2dec0 libmpeg2dec0-0.3.1-2mdk
So any clues..........please?!
Tom Williams
2003-08-02 17:17:03 UTC (over 21 years ago)
"-l" tells the linker (ld) what library to look for. It will prefix a "lib" in front of the string after the "-l", so "-lslang" means the linker is looking for "libslang". Try searching for "libslang" via Google.
Peace...
Tom
bright.1@virgin.net
2003-08-02 21:21:23 UTC (over 21 years ago)
Yeah. That worked. Thanks for your help.
Same problem here : http://bugzilla.gnome.org/show_bug.cgi?id=117014 install libslang1-devel and libgpm1-devel and recompile.
