transparent PNGs in IE
transparent PNGs in IE | Andrew Langdon-Davies | 23 Jul 10:47 |
transparent PNGs in IE | Mukund | 23 Jul 12:36 |
transparent PNGs in IE | David Neary | 23 Jul 14:27 |
transparent PNGs in IE | Mukund | 26 Jul 18:46 |
transparent PNGs in IE | David Neary | 26 Jul 20:07 |
transparent PNGs in IE | Jakub Steiner | 26 Jul 21:57 |
transparent PNGs in IE | Carol Spears | 26 Jul 20:30 |
I know there's already been a lot of discussion on this subject and I've
read pages and pages, but I'm still unclear. I realise that just about all
recent browsers support PNGs. But, is it or is it not possible for IE (v.
5, for example) to correctly display a PNG with a fully transparent
background so that anything behind it shows through? My PNGs are OK in
Mozilla, Netscape, Opera, Konqueror and Nautilus, but in IE they have a
rectangular white background that completely wrecks the effect.
TIA,
Andrew
| TIA,
| Andrew
It is possible to achieve this using DirectX on IE under Windows. http://support.microsoft.com/default.aspx?scid=kb;en-us;Q294714
The reason that IE does not support alpha may be due to a design issue, rather than their reluctance to support PNG. You can achieve 1-bit transparency for example.
Mukund
I know there's already been a lot of discussion on this subject and I've read pages and pages, but I'm still unclear. I realise that just about all recent browsers support PNGs. But, is it or is it not possible for IE (v. 5, for example) to correctly display a PNG with a fully transparent background so that anything behind it shows through? My PNGs are OK in
Yes. To do so, you need to make sure that your png is saved as an indexed image, rather than rgb (which png supports, but gif doesn't - this is why when you save as gif, you get a dialog asking you if it's OK to index the image sometimes).
To do this, go into the Image->Mode menu, and select Indexed as the mode of the image. Then choose a palette to use (automatic is usually OK), and save as png as you do normally.
The GIMP's png support is limited somewhat by its core support for indexed images - you can have one index entry completely transparent, but partial transparency (which is supported by png) is not supported for indexed images in the gimp.
Cheers, Dave.
On Wed, Jul 23, 2003 at 02:27:19PM +0200, David Neary wrote: | The GIMP's png support is limited somewhat by its core support | for indexed images - you can have one index entry completely | transparent, but partial transparency (which is supported by png) | is not supported for indexed images in the gimp.
Dave, does IE support the alpha channel with indexed PNG images? I would also like to know about the differences between IE/Win and IE/Mac w.r.t this feature.
Mukund
No, that's a big bad for IE. They support RGB pngs, but not RGBA, and they support Indexed PNGs with GIF style transparency, but not multiple palette entries with different alpha values. I'm afraid I know nothing about IE/Mac. I have never been a mac user.
For example images to test IE against this, have a look at this
enhancement request...
http://bugzilla.gnome.org/show_bug.cgi?id=86627
Cheers, Dave.
For example images to test IE against this, have a look at this enhancement request...
http://bugzilla.gnome.org/show_bug.cgi?id=86627Cheers, Dave.
internet explorer dropped support for mac, iirc. w3c bloggers dropped support for ie. i dropped support (temporarily) for netscape3.
if we drop support for broken browsers ie, any of them, and write things that should work, we could use png and show them how to add a gradient via css to a transparent background. some of the w3c cssers might already be doing this.
i am so sick of answering issues for other people. gimp follows standards. maybe gimp should start making them. no better app to grab the color to send to the background information in the css of any format.
anxious to never read about browser issues again in south lyon, carol
IE on the mac supported RGBA PNGs for as long as I remeber. It's a completely different browser.
cheers
