yet another install problem
yet another install problem | bright.1@virgin.net | 19 Jul 17:35 |
yet another install problem | Carol Spears | 19 Jul 19:30 |
OK. I am having serious trouble when trying to install gimp-1.2.5.tar.gz
This is what I get at the end of the 'make' procedure.
creating script-fu
make[4]: Leaving directory `/home/david/gimp-1.2.5/plug-ins/script-fu' make[3]: Leaving directory `/home/david/gimp-1.2.5/plug-ins/script-fu' Making all in perl
make[3]: Entering directory `/home/david/gimp-1.2.5/plug-ins/perl' make[3]: *** No rule to make target `all'. Stop. make[3]: Leaving directory `/home/david/gimp-1.2.5/plug-ins/perl' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/home/david/gimp-1.2.5/plug-ins' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/david/gimp-1.2.5' make: *** [all-recursive-am] Error 2
What does 'all recursive error' mean? Apart form something being wrong.
In addition I cannot get a requirement to install. The requirement is perl-pdl. I've downloaded it. this is the file perl-PDL-2.4.0-2mdk.i586.rpm. But when installing it complains about a series of perl files.
error: failed dependencies:
perl(ExtUtils::MakeMaker) is needed by perl-PDL-2.4.0-2mdk perl(File::Basename) is needed by perl-PDL-2.4.0-2mdk perl(Getopt::Std) is needed by perl-PDL-2.4.0-2mdk perl(strict) is needed by perl-PDL-2.4.0-2mdk perl(vars) is needed by perl-PDL-2.4.0-2mdk
I've tried using cpan to download the files. But perl-pdl still will not install../a recursive failed dependencies loop/...I fear.
I must admit I'm getting a little sick of running into problems just trying to update my version of gimp. So if anyone has any idea what is happening please let us know.
cheers
creating script-fu
make[3]: Entering directory `/home/david/gimp-1.2.5/plug-ins/perl' make[3]: *** No rule to make target `all'. Stop. make[3]: Leaving directory `/home/david/gimp-1.2.5/plug-ins/perl' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/home/david/gimp-1.2.5/plug-ins' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/david/gimp-1.2.5' make: *** [all-recursive-am] Error 2What does 'all recursive error' mean? Apart form something being wrong.
perl(ExtUtils::MakeMaker) is needed by perl-PDL-2.4.0-2mdk perl(File::Basename) is needed by perl-PDL-2.4.0-2mdk perl(Getopt::Std) is needed by perl-PDL-2.4.0-2mdk perl(strict) is needed by perl-PDL-2.4.0-2mdk perl(vars) is needed by perl-PDL-2.4.0-2mdkI've tried using cpan to download the files. But perl-pdl still will not install../a recursive failed dependencies loop/...I fear.
You should be able to build this gimp if you configure it without perl. I type "./configure --help" to find these magical configuration flags.
I wish I could help you to install perl properly. I think I am having some problems with my Debian Sarge perl and gimp. I am getting an error about threading being enabled and this implying that I am smart enough to know how to fix it. When I get a chance, I am going to try to work through it. I cannot even get to my photos right now, however ....
