Gimp jpeg compression
Gimp jpeg compression Randall Crook 05 Jul 08:09
  Gimp jpeg compression Sven Neumann 05 Jul 19:30
Randall Crook
2003-07-05 08:09:43 UTC (over 21 years ago)
Can enyone tell me if there is any way of changing the default jpeg compression ratio for the save option.
To ensure you you don't lose any quality after moding a jpeg I am currently forced to do a save as and manually setting the compression ratio to 1.
any help would be appretiated.
2003-07-05 19:30:41 UTC (over 21 years ago)
Randall Crook writes:
Yes, open plug-ins/common/jpeg.c in your favorite editor, change the default value and recompile.
To ensure that you don't lose any quality, you should really be using a different format than JPEG which is always a lossy format.
