Problem with paintbrush and convolver
| Problem with paintbrush and convolver | Fabio S. | 03 Jul 11:02 |
| Problem with paintbrush and convolver | Sven Neumann | 03 Jul 13:25 |
| Problem with paintbrush and convolver | Fabio S. | 03 Jul 17:54 |
| Problem with paintbrush and convolver | Sven Neumann | 03 Jul 19:58 |
Hi all,
I am experiencing a problem when I use one of these tools, but it is a strange problem and I find some difficulties in explaining it. Nevertheless, let me try....
If I select the paintbrush and I draw a random curve on my picture, every now and then some of the pixels of the curve are "displaced" either horizontally or vertically. The effect is more visible with a not so small brush (either soft or hard) and when the image is zoomed at least at 1:1
By itself this is quite annoying but it is not all: the effect is, in fact, an illusion. The line, in reality, is well drawn and I can realize this by the fact that if I zoom in and then out the effect disappears!!!
Did anybody experienced the same thing? What is the cause? How can I correct this?
Thank you for your help
Fabio
PS: I also have a problem in compiling gimp 1.2.5 under mandrake 9.0: all
needed devels packages are installed, ./configure says everything is ok
and compilations starts ok and goes on for 10-15 minutes, then I get an
error.
But, for this, maybe it is better if I include in another post the last
few lines of compilation output...
"Fabio S." writes:
This is a known bug which is fixed in later 1.3 releases and if I remember correctly the fix has been backmerged to version 1.2.5 as well.
You remember well: in 1.2.5 it is fixed. So, now then I come to the other problem: compilation of 1.2.5... What follows at the end of the message is the error I get when compiling: does it give anyone a clue on what is wrong? I want to stress that ./configure gives no errors and, moreover, compilation was fine on another desktop on which I have the same distribution (mdk 9.0) with _exactly_ the same *devel*.rpm packages.
If I will succeed in compiling, then the only wish about paintbrush would be to see its size, but I know I am not the only one wishing this and we have still to wait a little... :-(
Since I am talking about paintbrush, I have another question:
in its "Tool options" box, there is a voice:
Pressure Sensitivity
with four choices:
Opacity Hardness Size Color
Well, I must admit that I can't see any difference in the behavior of the
paintbrush whichever mode I choose.
I also looked on the gimp manual and on "grokking the gimp", but I
couldn't find any explanation about this.
Thank you very much
Fabio
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../.. -I../../intl
-I/usr/include/gtk-1.2 -I/usr/include/glib-1.2 -I/usr/lib/glib/include
-I/usr/X11R6/include -I/usr/local/include
-DLOCALEDIR=\""/usr/local/share/locale"\" -DGTK_DISABLE_COMPAT_H -g -O2
-Wall -c aa.c
cc1: warning: changing search order for system directory
"/usr/local/include"
cc1: warning: as it has already been specified as a non-system directory
aa.c: In function `get_type_from_string':
aa.c:110: warning: initialization from incompatible pointer type
aa.c: In function `type_dialog':
aa.c:367: warning: initialization from incompatible pointer type
aa.c:377: warning: passing arg 4 of `gtk_signal_connect' discards
qualifiers from pointer target type
/bin/sh ../../libtool --mode=link gcc -g -O2 -Wall -o aa aa.o
../../libgimp/libgimpui.la ../../libgimp/libgimp.la -laa -L/usr/X11R6/lib
-lgtk -lgdk -rdynamic -lgmodule -lglib -ldl -lXi -lXext -lX11 -lm
gcc -g -O2 -Wall -o .libs/aa aa.o -rdynamic
../../libgimp/.libs/libgimpui.so -L/usr/X11R6/lib
../../libgimp/.libs/libgimp.so /usr/lib/libaa.so -lslang -lgpm
/usr/lib/libgtk.so /usr/lib/libgdk.so /usr/lib/libgmodule.so
/usr/lib/libglib.so -ldl -lXi -lXext -lX11 -lm -Wl,--rpath
-Wl,/usr/local/lib
/usr//bin/ld: cannot find -lgpm
collect2: ld returned 1 exit status
make[3]: *** [aa] Error 1
make[3]: Leaving directory
`/home/stumbo/download/gimp-1.2.5/plug-ins/common'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/stumbo/download/gimp-1.2.5/plug-ins'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/stumbo/download/gimp-1.2.5'
make: *** [all-recursive-am] Error 2
"Fabio S." writes:
Since I am talking about paintbrush, I have another question: in its "Tool options" box, there is a voice: Pressure Sensitivity
with four choices:
Well, I must admit that I can't see any difference in the behavior of the paintbrush whichever mode I choose.
These options only affect the way the brush reacts when used with a pressure sensitive device (tablet).
-I/usr/X11R6/include -I/usr/local/include -DLOCALEDIR=\""/usr/local/share/locale"\" -DGTK_DISABLE_COMPAT_H -g -O2 -Wall -c aa.c
cc1: warning: changing search order for system directory "/usr/local/include"
cc1: warning: as it has already been specified as a non-system directory aa.c: In function `get_type_from_string': aa.c:110: warning: initialization from incompatible pointer type aa.c: In function `type_dialog':
aa.c:367: warning: initialization from incompatible pointer type aa.c:377: warning: passing arg 4 of `gtk_signal_connect' discards qualifiers from pointer target type
/bin/sh ../../libtool --mode=link gcc -g -O2 -Wall -o aa aa.o ../../libgimp/libgimpui.la ../../libgimp/libgimp.la -laa -L/usr/X11R6/lib -lgtk -lgdk -rdynamic -lgmodule -lglib -ldl -lXi -lXext -lX11 -lm gcc -g -O2 -Wall -o .libs/aa aa.o -rdynamic ../../libgimp/.libs/libgimpui.so -L/usr/X11R6/lib ../../libgimp/.libs/libgimp.so /usr/lib/libaa.so -lslang -lgpm /usr/lib/libgtk.so /usr/lib/libgdk.so /usr/lib/libgmodule.so /usr/lib/libglib.so -ldl -lXi -lXext -lX11 -lm -Wl,--rpath -Wl,/usr/local/lib
Your aalib installtion is broken. You should either deinstall aalib or install the gpm library which is obviously required by aalib but not available (due a broken package dependency). If you deinstall aalib, you will not have the aa plug-in available in GIMP.
