Bezier Curves in 1.3.16
Bezier Curves in 1.3.16 Jeff Trefftzs 28 Jun 19:28
  Bezier Curves in 1.3.16 Jakub Steiner 30 Jun 10:47
  Bezier Curves in 1.3.16 Sven Neumann 30 Jun 14:17
   Bezier Curves in 1.3.16 Jeff Trefftzs 30 Jun 21:50
Jeff Trefftzs
2003-06-28 19:28:17 UTC (almost 22 years ago)
Greetings, fellow gimpers -
It appears that the bezier curve tool usage has changed between 1.2.x and 1.3. In 1.2 I could close the curve, click inside the closed curve, and then proceed to edit the points, adjusting the curve to fit whatever object I was trying to define. In 1.3 I seem unable to close the curve at all, leading me to believe I am missing something *really* elementary. Can anyone point me in the right direction?
TIA,
Jakub Steiner
2003-06-30 10:47:51 UTC (almost 22 years ago)
Hi there,
I'm pointing you to the direction of Dr. Path Tool (aka Simon Budig), where you can express your deepest sympathies to the man who boldly went where everyone else failed. ;)
Yes, you are right about the path tool being rewritten. It is currently not possible to close a path, it's work in progress.
cheers
2003-06-30 14:17:52 UTC (almost 22 years ago)
Jeff Trefftzs writes:
Yes, the path tool is being completely rewritten.
You will have to wait until this feature has been implemented in the new tool. It's simply not there yet.
Jeff Trefftzs
2003-06-30 21:50:20 UTC (almost 22 years ago)
Ahhh! No wonder. Thanks for the news. The more I use the newest Gimp, the more I find myself liking it, even though it does take a bit of getting used to ...
