Installing gimp with libraries in a non-standard place
Installing gimp with libraries in a non-standard place Gebhart, Mark A 23 Jun 21:48
  Installing gimp with libraries in a non-standard place Sven Neumann 24 Jun 02:07
Gebhart, Mark A
2003-06-23 21:48:34 UTC (almost 22 years ago)
I am trying to install gimp-1.0.4 and when I run the configure script I get warning saying that the:
aa
mpeg
xpm
png
jpeg
plugins will not be built because it can not find the associated .h files. On my system these files are installed under /opt/sfw/include. Anyone know if there is a way to get configure to look somewhere else beside the standard places. I have tried different flags but have had no luck with --includedir=/opt/sfw or --with-incs-from=/opt/sfw.
Thanks in advance, Mark
2003-06-24 02:07:08 UTC (almost 22 years ago)
"Gebhart, Mark A" writes:
GIMP-1.0.4 is horribly outdated and unmaintained for a long time. You should be using GIMP-1.2.5.
aa
mpeg
xpm
png
jpeg
You need to set CPPFLAGS environment variable as described in the file INSTALL.
