1.3.15 Zoom issue
1.3.15 Zoom issue Kevin Waterson 20 Jun 09:33
  1.3.15 Zoom issue Sven Neumann 20 Jun 10:21
   1.3.15 Zoom issue Kevin Waterson 20 Jun 14:15
    1.3.15 Zoom issue Sven Neumann 20 Jun 13:16
Kevin Waterson
2003-06-20 09:33:08 UTC (almost 22 years ago)
1.3.15 Zoom issue
Not sure if this has been reported, but I am having issues with the zoom in, the + key is not functioning and I need to use the menu to zoom in, very time consuming.
On the positive side, the crashing I was experiencing when dealing with files of 120 Meg+ in 1.3.13 has gone away.
Good work all
Kind regards Kevin
2003-06-20 10:21:30 UTC (almost 22 years ago)
1.3.15 Zoom issue
Kevin Waterson writes:
It is working, we just changed the default key shortcut from '=' to '+'. If you don't like this, you can enable Dynamic Keyboard Shortcuts in the Preferences Dialog and reconfigure the keybinding.
2003-06-20 13:16:03 UTC (almost 22 years ago)
1.3.15 Zoom issue
Niether the '+' or '=' keys work to zoom in. the '-' key works fine to zoom out.
It works for me. Please check which key is bound to the "Zoom In" in the View->Zoom menu.
Kevin Waterson
2003-06-20 14:15:23 UTC (almost 22 years ago)
1.3.15 Zoom issue
Kind regards
Kevin
