pangoft2 for gimp 1.3
8 of 8 messages available
pangoft2 for gimp 1.3 Brian Perkins 30 May 02:53
  pangoft2 for gimp 1.3 Sven Neumann 30 May 12:37
pangoft2 for gimp 1.3 José Manuel García-Patos 30 May 16:51
  pangoft2 for gimp 1.3 Sven Neumann 30 May 18:08
   pangoft2 for gimp 1.3 Carol Spears 01 Jun 22:36
    pangoft2 for gimp 1.3 Carol Spears 01 Jun 22:48
    pangoft2 for gimp 1.3 Sven Neumann 02 Jun 13:17
pangoft2 for gimp 1.3 José Manuel García-Patos 01 Jun 22:36
Brian Perkins
2003-05-30 02:53:31 UTC (almost 22 years ago)
I am attempting to compile gimp1.3 and during the configure stage I get the error that pangoft2.pc cannot be found. I have installed freetype and recompiled pango and also tried setting the PKG_CONFIG_PATH environment variable to the directory containing pangoft2.pc. Is there something special I need to do when compiling pango to set the optional freetype support? Also as a side question that came to me during this troubleshooting process; how do I permanently set such environmental variables such as the on above?
Thank you for any help.
Brian
2003-05-30 12:37:01 UTC (almost 22 years ago)
Brian Perkins writes:
Pango should find freetype when you run configure. When configure finishes, it will list the backends it is going to build. But you mentioned that there is a pangoft2.pc file already. This indicates that pangoft2 was built. Please check that pangoft2 is version 1.2.0 or newer. You can use pkg-config to do that:
pkg-config --modversion pangoft2
2003-05-30 16:51:53 UTC (almost 22 years ago)
You should edit the pango configure script and uncomment the lines related to pangoft2.pc. They´re more or less at the beginning of the file. It´s fairly easy to do that, the hard part was to figure it out (at least for me). Then run configure. As Sven said it should appear in the listing of things to build.
José Manuel García-Patos Madrid
2003-05-30 18:08:38 UTC (almost 22 years ago)
José Manuel García-Patos writes:
Editing the configure script is definitely not the right way of solving such problems. Please don't suggest such stuff (even if it somehow worked for you).
Carol Spears
2003-06-01 22:36:22 UTC (almost 22 years ago)
On 2003-05-30 at 1808.38 +0200, Sven Neumann typed this:
Jos? Manuel Garc?a-Patos writes:
You should edit the pango configure script and uncomment the lines related to pangoft2.pc. They?re more or less at the beginning of the file. It?s fairly easy to do that, the hard part was to figure it out (at least for me).
aww,
don't just say don't do that. at least say why and the better way to fix it.
2003-06-01 22:36:55 UTC (almost 22 years ago)
Don´t take my advice if it´s something bad. But let me correct myself. I meant to say Makefile, not configure. Sorry about that. Too. One thing is giving bad advices, and another giving faulty ones. Sorry again.
ps. I sent a correction earlier, but I guess it didn´t get through for some reason.
Carol Spears
2003-06-01 22:48:27 UTC (almost 22 years ago)
On 2003-06-01 at 1636.22 -0400, Carol Spears typed this:
aww,
because it sounds so mean.
2003-06-02 13:17:10 UTC (almost 22 years ago)
Carol Spears writes:
aww,
Well, I would have done that but the original message didn't give enough information to allow me to give a useful advice.
BTW: Editing the Makefile is about as wrong as editing the configure script.
