Auto correct
Auto correct Mike 26 May 16:13
  Auto correct Sven Neumann 26 May 17:53
   Auto correct Carol Spears 26 May 23:33
Auto correct Tom Williams 26 May 17:45
Mike
2003-05-26 16:13:05 UTC (almost 22 years ago)
Auto correct
When I used to use PS 5 they had a feature under "Image" called "Auto Correct". I used to use that as a start for working with old and washed out pictures. Being new to Gimp I haven't found this feature yet. Is this option an open one or do I just have to wish for it?
Mike Wheelock
Tom Williams
2003-05-26 17:45:44 UTC (almost 22 years ago)
Auto correct
Mike Wheelock
Try right-clicking on the image, then "Image/Colors/Levels" then the "Auto" button. This is with gimp 1.2.
Peace...
Tom
2003-05-26 17:53:40 UTC (almost 22 years ago)
Auto correct
"Mike" writes:
There are a couple of automatic color correction functions in Image->Colors->Auto that you might find useful. I'd suggest to use the Levels tool however. It has a button that does Automatic color correction but also allows to do some manual fine-tuning.
Carol Spears
2003-05-26 23:33:55 UTC (almost 22 years ago)
Auto correct
On 2003-05-26 at 1753.40 +0200, Sven Neumann typed this:
"Mike" writes:
i started working with the levels dialog right after i read or heard that the levels needed to go from end to end in that dialog.
it is quite impressive what you can do with the levels dialog.
gimp-1.3 has these nifty colorpickers that help to adjust for what you think should be black and what you think should be white. so far, i have not been able to determine what is a good gray (the center dropper).
anyways, i highly suggest playing with this dialog on any photo. seeing it will be better than reading about it.
