how to
how to craniac (Steve Crane) 16 Apr 17:06
how to craniac (Steve Crane) 16 Apr 17:45
  how to sam ende 16 Apr 18:33
2003-04-16 17:06:53 UTC (about 22 years ago)
how to
I believe, on Windows, drag-and-drop works
Yep, I use it all the time.
Also, it seems there is a port of gimp-remote for Windows. Check it out at http://sourceforge.net/projects/gimp-win-remote/.
-- Steve Crane
http://craniac.afraid.org
2003-04-16 17:45:59 UTC (about 22 years ago)
how to
i'm on debian k6.
In that case you probably have gimp-remote already, I think it is a standard part of the GIMP install under Linux. If not just google for it and you should find it.
Cheers.
Steve Crane
sam ende
2003-04-16 18:33:07 UTC (about 22 years ago)
how to
On Wednesday 16 April 2003 16:45, craniac (Steve Crane) wrote:
i'm on debian k6.
thank you.
sammi
