GIMP for Print?
GIMP for Print? Narramore 06 Apr 04:23
  GIMP for Print? Carol Spears 06 Apr 08:52
   GIMP for Print? Narramore 06 Apr 13:32
Narramore
2003-04-06 04:23:15 UTC (about 22 years ago)
GIMP for Print?
The impression that I have gotten about GIMP is that it is second to none for web graphics but when it comes to print that others are better suited.
I need to make a cover for a book and am considering whether I should attempt to do so with GIMP or if I would be much better off using some other program for the job. I don't think I really need state-of-the-art, just something that will look good. This is for an initial print run and if the book does well I may hire a pro next time around.
Any suggestions on other image editors? If GIMP is not the choice for print media I will probably try to buy a non-current (meaning older and cheap) version of Photoshop or Illustrator, etc. on eBay.
Thanks,
Matt
Carol Spears
2003-04-06 08:52:44 UTC (about 22 years ago)
GIMP for Print?
On 2003-04-05 at 2123.15 -0500, Narramore typed this:
one of the gimp authors is active on this list off and on. he made his cover with The GIMP and detailed it to this list last june: http://lists.xcf.berkeley.edu/lists/gimp-user/2002-June/004709.html there is some more information if you follow the thread some.
there is a thumbnail of the cover here: http://mmmaybe.gimp.org/books/
good luck carol
Narramore
2003-04-06 13:32:07 UTC (about 22 years ago)
GIMP for Print?
Thank you for the information. I checked the links out and I can see they will be very helpful.
Matt
good luck carol
