turn tools loose??
turn tools loose?? Gracia M. Littauer 01 Mar 22:27
  turn tools loose?? Judy Wilson 01 Mar 23:44
  turn tools loose?? sam ende 02 Mar 21:34
turn tools loose?? Tom Williams 01 Mar 23:24
Gracia M. Littauer
2003-03-01 22:27:26 UTC (almost 22 years ago)
turn tools loose??
a friend asked this question which I couldn't answer since I haven't really used the tools so far.
"I hate to ask such a dumb question on a public list, but I still can't figure out how to get a tool to turn loose! I pick up, for example, the rotator tool. I'm finished rotating, but I can't put the tool down."
Any answers????
Tom Williams
2003-03-01 23:24:34 UTC (almost 22 years ago)
turn tools loose??
Any answers????
What I usually do is select the "Select rectangular regions" tool which is the first tool in the upper left-hand corner of the toolbox. This is the default tool that is selected when you first start gimp, unless you configure gimp otherwise. :)
Peace....
Tom
Judy Wilson
2003-03-01 23:44:03 UTC (almost 22 years ago)
turn tools loose??
* Gracia M. Littauer [030301 16:06]:
but I still
I used to be puzzled by this, too, but I have discovered anything I want to do that doesn't involved another tool, I can do while I still have that tool. Like print. Sometimes I just select another tool, like "move". I've gotten used to it.
Judy
sam ende
2003-03-02 21:34:25 UTC (almost 22 years ago)
turn tools loose??
Any answers????
selct a differnt tool to replace it, my 'default' is the move tool.
sammi
