Fwd: Re: USB scanner, Xsane and Gimp
Fwd: Re: USB scanner, Xsane and Gimp Fred Bazolo 18 Feb 04:08
  Fwd: Re: USB scanner, Xsane and Gimp Nigel Ridley 23 Feb 19:24
Fred Bazolo
2003-02-18 04:08:18 UTC (almost 23 years ago)
---------- Forwarded Message ----------
Subject: Re: [Gimp-user] USB scanner, Xsane and Gimp Date: Mon, 17 Feb 2003 22:01:25 -0500 From: Fred Bazolo
To: Nigel Ridley
I am running Libranet 2.7 kernel 2.4.19 (a Debian variant) and trying to get a Benq (was Acer) 4300U USB scanner to work. The Gimp is 1.2.3
Blessings,
Nigel Ridley
hello again Nigel,
I'm guessing on this. I use an Epson. You probably still have to configure the SANE backend. I don't know what that would be called for your scanner, but for an Epson it's a file called epson.conf. It should be located either in /etc/sane.d or in /usr/local/etc/sane.d - wherever your linux distro installs SANE. Edit the file and make sure that the following line is the only information in the file:
usb /dev/usbscanner0
You may have to replace "/dev/usbscanner0" with the actual device name, but from your information that sounds like what it is.
You don't use an epson, so you will have to look for something like acer.conf or benq.conf, or even ( more probably I think ) snapscan.conf. This is because, after checking the SANE homepage, your scanner uses the snapscan backend.
You may also have to reboot. I don't know, and I'm nobodies linux guru! Good luck. let me know if this works.
By the way, I got most of my information from the SANE homepage, www.freecolormanagement.com/SANE and .../Documentation/usb/scanner.txt. You would probably also want to visit
http://www.mostang.com/sane/man/sane-snapscan.5.html.
Nigel Ridley
2003-02-23 19:24:30 UTC (over 22 years ago)
To: Nigel Ridley
Blessings,
Nigel Ridley
hello again Nigel,
By the way, I got most of my information from the SANE homepage, www.freecolormanagement.com/SANE and .../Documentation/usb/scanner.txt. You would probably also want to visit http://www.mostang.com/sane/man/sane-snapscan.5.html.
