Parameter Conversion for PS USM
Parameter Conversion for PS USM Kevin Myers 21 Jan 18:32
Parameter Conversion for PS USM HolyCow 21 Jan 18:37
Kevin Myers
2003-01-21 18:32:22 UTC (about 22 years ago)
Regarding preview, what I would suggest is to select a small area of your image to process first. Then after you get your settings worked out, revert to processing the entire image.
s/KAM
----- Original Message ----- From: "HolyCow"
To:
Sent: Tuesday, January 21, 2003 11:37 AM Subject: [Gimp-user] Parameter Conversion for PS USM
One of the more powerful features of Photoshop is the USM (shapen, umask) feature. GIMP has a similar funnction (Windows version 1.2.4). However, the paramter settings are not one-to-one. Does anyone have suggestions on how to convert setting from the PS USM tool into the GIMP tool? The PS version also has a preview window which helps reduce trial and errors selections. I cannot find a similar feature under GIMP.
Mooooo
HolyCow
2003-01-21 18:37:19 UTC (about 22 years ago)
Mooooo
