color conversion tips?
3 of 4 messages available
color conversion tips? Thomi Richards 24 Dec 03:07
thomi@thomi.imail.net.nz 07 Oct 20:15
  color conversion tips? Jeff Trefftzs 25 Dec 00:31
   color conversion tips? Guillermo S. Romero / Familia Romero 25 Dec 17:45
Thomi Richards
2002-12-24 03:07:07 UTC (almost 23 years ago)
can someone suggest a way to "make very near white colors pure white?".
so far, I've been selecting by color while holding down the shift key, but it takes ages, and is a bit slow.
what might work, is if you could select colors by selecting an area of a histogram. any ideas?
Jeff Trefftzs
2002-12-25 00:31:58 UTC (almost 23 years ago)
Selection by histogram is what you get with Image->Colors->Threshold. You can either do it using a copy of your original image in RGB(A) or, to get really sneaky, you can decompose your image into another colorspace (HSV, for example) and achieve the effect you want by thresholding the appropriate Hue, or Value image, then using the selection on your original image.
You said you wanted to select the colors that were "close to" white. To do this, just use threshold on the value channel and pick up only that part of the histogram that is "close to" white. This will give you a bi-level image from which you can then select the white parts, using the selection on the original image and filling with white (or whatever other color you want).
HTH,
2002-12-25 17:45:05 UTC (almost 23 years ago)
trefftzs@tcsn.net (2002-12-24 at 1531.58 -0800):
I would use Levels or Curves to push to white, simpler and smoother results than Threshold and Fill. For other colours, no, but for white, or any colour you can control via channels (directly or decompose & compose back), yes.
GSR
