Advice with gimp 1.3
Advice with gimp 1.3 zeus 22 Dec 22:42
  Advice with gimp 1.3 Niklas 22 Dec 13:20
   Advice with gimp 1.3 Carol Spears 23 Dec 19:55
  Advice with gimp 1.3 Carol Spears 23 Dec 20:40
Advice with gimp 1.3 daniel cline 23 Dec 20:40
Advice with gimp 1.3 Eric Pierce 25 Dec 08:49
Niklas
2002-12-22 13:20:57 UTC (almost 23 years ago)
Hey,
1.3.x is for testing use and should not be used for everyday work. So waiting for stable 1.4.0 is a good thing to do. However testing 1.3.x is really good. :-)
For the CMYK thingys you are asking for, work is being done from what I know and this might be in the 1.2.4 when it comes out as stable.
New things that is being add to 1.3 is best to view from CVS ChangeLog. Right now it seems to be the 1.2.4 that is the main issue to release and this seems to go really well. So use 1.2.3 for all day work and 1.3.x for testing things.
On Sun, 2002-12-22 at 22:42, zeus wrote:
OK...what's make gimp 1.3 worth to use? Should i wait until stable version.
Is the ne GIMP support CMYK color mode? Because i need CMYK for printing.
Is there any page where i can view new things with GIMP 1.3??
Domo Arigatou gozaimasu....
zeus
2002-12-22 22:42:00 UTC (almost 23 years ago)
Carol Spears
2002-12-23 19:55:57 UTC (almost 23 years ago)
On 2002-12-22 at 1320.57 +0100, Niklas typed this:
well, there is a typo here, i think. but even fixing the typo the information is not so acurate.
cmyk is planned for gimp-2.0, and gegl.
gimp-1.2.4 is due out anyday now (important anniversery is coming up also ;) ). it will not have cmyk support, but the colorhtml plug-in will produce valid css now (which is far more important to me than expensive and weird color conversions).
Carol Spears
2002-12-23 20:40:21 UTC (almost 23 years ago)
On 2002-12-22 at 1342.00 -0800, zeus typed this:
truthfully, gimp-1.3 and gimp-1.2 crash about the same amount for me. gimp-1.3 is a development package, you should save more. gimp-1.2 is acting up on me more and more lately. i don't know enough about things to follow up on my crashes. but it does seem to be that the only thing in common with all of them is X, which seems to be changing alot since December 2000. so, i use both and save often.
it is easy to run both gimps, the developers have been thoughtful about this since sometime in the middle of the 1.1 series. currently i have a running gimp-1.0.2, gimp-1.1.10 (depends on how you define running for that one though), gimp-1.2.4 (from cvs) and also a gimp-1.3.11 (also from cvs). i had to be careful when installing gimp-1.0.2 but the others worked very nicely.
i am pretty sure that the gimp they currently call stable will call itself "gimp" and the rest can be started by asking for them by name "/usr/local/bin/gimp-1.3" for me.
the dockable apps make it totally worth it, imo. if i need some function that gimp-1.3 lacks i pull up gimp-1.2. they have moved some of the Image and Layers menu items around, so it gets difficult to keep that straight for me. but the unstable gimp seems fairly stable to me, just lacking some of the things i like to use. also, more opinions need to be expressed about the "color sliders on lsd" to the developers.
here are some urls of screenshots of gimp-1.3: dialog on lsd http://sven.gimp.org/colorscale.png a dock i haven't accomplished yet http://sven.gimp.org/foo.png a dock i have accomplished http://sven.gimp.org/toolbox-mockup.png the disappearing button borders
http://sven.gimp.org/toolbox-relief.gif (note the file format, this is one of the biggest anti-gif people i know, but it is still the option for an animation if you want people to see it) some bigger screen shots:
http://carol.gimp.org/thefamily.png (all the gimps i had running sometime ago) http://carol.gimp.org/screen-02-08-01.png (several of the dialogs before i figured out the docks and before the button boundries disappeared.
daniel cline
2002-12-23 20:40:33 UTC (almost 23 years ago)
PLEASE UNSUBSCRIBE ME!!!!!!
Eric Pierce
2002-12-25 08:49:04 UTC (almost 23 years ago)
Carol,
I'm running 1.3.10. Can I ask you how you accomplished this[1] in 1.3.x?
Thanks! Eric P.
1. The docking and putting the color selector in the main window
___
