Replace colors (beginner question)
2 of 3 messages available
Replace colors (beginner question) joel grimes 03 Sep 06:16
joelgrimes@hotmail.com 07 Oct 20:15
  Replace colors (beginner question) Jeff Trefftzs 03 Sep 07:01
joel grimes
2002-09-03 06:16:09 UTC (over 22 years ago)
I'm trying to replace all of one color with another.
I tried right-click, select-by color, then pick an item with the color I want to replace - it seems to select properly.
THEN I try and use bucket fill to fill that selection and I get nothing.
I would expect that this would replace the entire selection with the current fg color. It isn't - I think it's just replacing it with color of the selected region (i.e. it does nothing).
New user, using windows
__________________
Jeff Trefftzs
2002-09-03 07:01:25 UTC (over 22 years ago)
Are you sure that (a) you are filling with the foreground color and (b) that you have changed the foreground color? I just tried this, and it worked fine for me. But you do need to make sure that the foreground color has been changed. If you've selected a blackish region to start with, and the fg color is still black, nothing will appear to have happened.
