dividing a page of images into individual images
dividing a page of images into individual images rob 22 Jul 19:01
  dividing a page of images into individual images Roland Roberts 22 Jul 19:36
   dividing a page of images into individual images rob 23 Jul 13:07
   dividing a page of images into individual images rob 23 Jul 13:08
dividing a page of images into individual images Geoffrey 22 Jul 19:03
rob
2002-07-22 19:01:03 UTC (over 23 years ago)
hi,
I'm trying to catalog my photos I've got a negative scanner which scans them in 12 twelve at a time (epson 2450 photo) is there a script I can run it through to get 12 individual images?
Geoffrey
2002-07-22 19:03:55 UTC (over 23 years ago)
rob wrote:
hi,
You can mark the separation between images with guides and then use image->transforms->guillotine to create the separate images.
Roland Roberts
2002-07-22 19:36:57 UTC (over 23 years ago)
"rob" == rob writes:
rob> I'm trying to catalog my photos I've got a negative scanner rob> which scans them in 12 twelve at a time (epson 2450 photo) is rob> there a script I can run it through to get 12 individual rob> images?
I'm attaching an undocumented script I use to scan film and slides with my epson 2450 using scanimage. Here's how I used it this morning to scan a set of 12 images while I was commuting to work.
( for x in 1 2 3 4 5 6 7 8 9 10 11 12; do F=$((x+3)); scanfilm --strip $x --file $(printf "f%02d.tif" $F) --format tiff --resolution 2400 --depth 16; done) > scan.log 2>&1 &
And here is a scan from a couple days ago when I had uncut slide film:
( for x in 3 4 8 9 10; do F=$((x+2)); scanfilm --strip $x --positive --file $(printf "%02d.tif" $F) --format tiff --resolution 2400 --depth 16; done) > scan.log 2>&
o The --strip uses the 35-mm strip holder and assumes negative film. o The --slide uses the 35-mm (mounted) slide holder and assumes positive film.
o The film type may be overridden via --positive or --negative. o Unrecognized options are passes through as-is (e.g., --resolution, --depth, --format). No promises that it won't break on somthing.
Note that I don't have anything set up for medium format film yet. I have a roll I need to scan, so I'll probably add that in the next week or so.
roland
rob
2002-07-23 13:07:30 UTC (over 23 years ago)
roland
I'm so stupid this is much better way to do things :)
I think it'd be a good idea if the ability to select individaul negatives etc went in the driver. I don't know if this is possible but it'd be much simpler. I'll send an email to sane-devel I think.
Thanks again this was exactly what I wanted to be able to do. :)
rob
2002-07-23 13:08:03 UTC (over 23 years ago)
roland
