N00b question: why is Photocopy filter not showing up in Gimp2.0 on Mac/Leopard/fink?
magicapn-fb@yahoo.com
2008-08-20 01:27:19 UTC (almost 17 years ago)
OK, so Gimp2.0 is all that I see available in Fink on Leopard. But when I go to the gimp.org site, the only documentation is for 2.2 and 2.4. When I google Gimp2.0, I get redirected to the 2.2 documentation. I must be missing something, but what?
Anyway, the 2.2 documentation says this:
http://docs.gimp.org/2.2/en/plug-in-photocopy.html
And when I go to Filters->Artistic in Gimp2.0, there is only the following (no Photocopy filter):
Apply Canvas Cubism
GIMPressionist
Oilify
Am I just out of luck until 2.2 is ready for Fink?
Thanks so much for bearing with me.
--Barrie
Jon Cosby
2008-08-20 01:52:12 UTC (almost 17 years ago)
GIMP 2.0 is over 4 years old. Are you sure about the version? Enter
gimp -v
in a terminal. What is the output?
jon
2008-08-20 04:05:31 UTC (almost 17 years ago)
gimp -v
Hi Jon,
Thanks for the quick reply. Here you go:
pythia:barrie$ /sw/bin/gimp-2.0 -v GIMP version 2.0.6
(Apologies for the format of this message; I'm reading from the archives as I misguidedly chose digest mode when subscribing).
Thanks, Barrie
2008-08-20 11:14:14 UTC (almost 17 years ago)
Von: magicapn-fb@yahoo.com
There seem to be 2.4.5 packages:
http://pdb.finkproject.org/pdb/package.php/gimp2
Don't know which of them is Leopard (please use the version numbers instead of the code names), though.
HTH, Michael
2008-08-26 18:07:16 UTC (almost 17 years ago)
Hi Michael,
Sorry about the delay in responding; I've been away from the keyboard for the last few days.
Thank you--yes, I don't think 2.0 has that feature. I noticed a thread right before mine in the archives where someone recommended a binary version of Gimp 2.4.5 that runs on Leopard (Mac OS X 10.5.4) and doesn't require Fink. I installed that and am now up and running with photocopy filter.
I can see how that would be confusing--sorry about that. See version # above.
Thanks so much! This community is a wonderful resource and I really appreciate it.
--Barrie
