gimp script-fu
gimp script-fu Helen 02 Aug 20:59
  gimp script-fu saulgoode@flashingtwelve.brickfilms.com 02 Aug 22:12
   gimp script-fu Helen 03 Aug 03:28
    gimp script-fu David Gowers 03 Aug 05:58
    gimp script-fu saulgoode@flashingtwelve.brickfilms.com 03 Aug 09:00
Helen
2008-08-02 20:59:55 UTC (over 17 years ago)
gimp script-fu
In the previous verion of Gimp that I was using until recently, there was a Script-fu tab, with things like Old Photograph. That was gimp 2.2.10.
Now, I've upgraded to 2.4, and I no longer have the script-fu features.
Is there something I can do to recover this feature?
TIA, Helen
2008-08-02 22:12:02 UTC (over 17 years ago)
gimp script-fu
Quoting Helen :
Almost all of the commands that used to be available under the Script-fu menu are still available; they've just been moved to more appropriate locations in the menus. Until you become familiar with their new locations, you can use the "Xtns->Plug-in Browser" to find the new location.
For example, typing "old photo" into the Plug-in Browser provides its location as being "Filters->Decor->Old Photo".
Helen
2008-08-03 03:28:22 UTC (over 17 years ago)
gimp script-fu
Thank you -- It's surprising how much time I can spend looking in the wrong places (googling
for this instead of just asking).
I'm sure there are other script-fu filters I had been running, but can't ask for them by name because I
don't remember what they were. But you did say "almost all ..." so I guess there are some that
were included in earlier versions but no longer? Is that the case? We've lost some?
Would it be too much to ask for a kind of rundown on what's been lost, what's still available?
And whether the "lost" features might later be "found"? Thanks again,
Helen, using Gimp 2.4 on linux, Suse11
On Sat, Aug 2, 2008 at 4:12 PM, wrote:
Quoting Helen :
David Gowers
2008-08-03 05:58:45 UTC (over 17 years ago)
gimp script-fu
Hi Helen,
I cannot give you that, however, if you open the Procedure Browser and search 'script-fu' all of the available scripts will show up in the list of procedures.
David
2008-08-03 09:00:29 UTC (over 17 years ago)
gimp script-fu
Quoting Helen :
There were very few Script-fus that were "lost". Most were just relocated in the menus. A couple others were made obsolete because of improvements in other features -- for example, the 'save to brush' and 'save to pattern' are no longer needed because you can now "Edit->Paste as->Brush" and "Edit->Paste as->Pattern" (and better still, use your clipboard contents directly as a pattern or brush).
The only Script-fus I can think of that have been truly "lost" is a 'Blend' script written by Sven Neumann which would create an animated, fading transition between two layers, using a third layer as a backdrop, and a 'Flash' script (I believe also by Sven Neumann) which animated a white strip of light moving left-to-right across the image.
Both of those scripts are probably better accomplished with the GIMP Animation Package (GAP) but if you need them, I am sure that updated versions can be provided.
