Problem with psd files under Ubuntu
Problem with psd files under Ubuntu Heiko Schmidt 23 Jul 13:06
  Problem with psd files under Ubuntu Sven Neumann 24 Jul 21:28
Heiko Schmidt
2008-07-23 13:06:13 UTC (almost 17 years ago)
I'm currently not able to open psd files with Gimp. (SVN build under Ubuntu). During the process to opening the file the progress bar stops by ca 75%. With Gimp 2.4.5 the same. I can load all the those psd files under Windows with Gimp 2.4.6.
Here is a stack trace. Maybe someone can help. Would be appreciated.
/home/heik/gimpSVN/lib/gimp/2.0/plug-ins/psd (pid:6734): [E]xit, [H]alt, show [S]tack trace or [P]roceed: S
#0 0xb7efc410 in __kernel_vsyscall () #1 0xb76f98c3 in __waitpid_nocancel () from /lib/tls/i686/cmov/libpthread.so.0
#2 0xb7765965 in g_on_error_stack_trace () from /usr/lib/libglib-2.0.so.0 #3 0xb7765e85 in g_on_error_query () from /usr/lib/libglib-2.0.so.0 #4 0xb7d94394 in gimp_plugin_sigfatal_handler (sig_num=11) at gimp.c:1539 #5
#6 0x0804c718 in add_layers (image_id=1, img_a=0xbf856374, lyr_a=0x8064000,
#7 0x0804e28f in load_image (
#8 0x0804a484 in run (name=, nparams=3, param=0x8062480,
#9 0xb7d94a78 in gimp_main (info=0x8053d10, argc=6, argv=0xbf856604) #10 0x0804a6da in main (argc=0, argv=0x0) at psd.c:59 /home/heik/gimpSVN/lib/gimp/2.0/plug-ins/psd (pid:6734): [E]xit, [H]alt, show [S]tack trace or [P]roceed:
Heiko
2008-07-24 21:28:16 UTC (over 16 years ago)
Please file a bug report for this issue at http://bugzilla.gnome.org/ and attach an example file to the bug report. Thanks.
