Can't 'Save As' more than once (usually)
Can't 'Save As' more than once (usually) Hex1a4 30 Jun 02:15
  Can't 'Save As' more than once (usually) Sven Neumann 01 Jul 23:02
Hex1a4
2008-06-30 02:15:22 UTC (over 17 years ago)
I've an unusual problem. When I open and image (say xcf) then select 'Save As', change the extension to png in the 'Save Image' dialog, click 'Save' and don't touch the PNG settings in the 'Save as PNG' dialog, the image saves fine and I can repeat the process over and over--until I change PNG properties. Once I've changed a PNG property (compression ratio for instance) the image saves, but the next time I select 'Save As' the 'Save Image' dialog shows up blank--no widgets. I can still close the dialog and GIMP works fine. If I close the image and open it again, I can 'Save As' again but only once--the PNG properties are retained from the previous save. If I close GIMP the same happens every-time. I can 'Save As' as many times as I want, until I change PNG properties. If I open a second image, even if the 'Save Image' dialog shows up blank for the first, I can 'Save As' as many times as I want until I change PNG properties.
When it comes to other formats however (JPEG, PCX, XPM, XBM) I can 'Save As' only once regardless of whether or not I change image properties. Although, unlike with PNGs, if I close the image then reopen it I can 'Save As' once again, but only once. To save PNGs using 'Save As' I need to restart GIMP.
I'm running GIMP version 2.4.5 on Xubuntu 8.04, kernel 2.6.24-19.
There is a similar bug on Bugzilla where the GTK file chooser dialog crashes when using network directories. Could this be part of it, or something different? I'm not using network directories.
2008-07-01 23:02:08 UTC (over 17 years ago)
Looks like http://bugzilla.gnome.org/show_bug.cgi?id=483502 to me.
