Move tool specifics and paste alignment
Move tool specifics and paste alignment Michael Armida 24 Jun 04:27
  Move tool specifics and paste alignment David Gowers 27 Jun 11:05
Michael Armida
2008-06-24 04:27:05 UTC (over 16 years ago)
I'm getting used to the GIMP analogues to a few different operations I'm used to under Photoshop, and having some trouble. Two questions relating to the move tool:
- I have read about the move tool modes and the ctrl-alt shortcut to move a portion of a layer. I would like to be able to do this and then use the keyboard to move the contents of the selection, just like I would by dragging the selection with the mouse.
- Once moving a selection, is there a way to make it only move in cardinal directions?
Also, if I do need to resort to cutting out a portion of an existing layer to reposition it, how do I paste it back in the same spot from which it came? When I cut out a selection and then immediately paste, I currently get the floating layer repositioned near the top left of my image.
Thanks for your time and help.
- Michael
David Gowers
2008-06-27 11:05:31 UTC (over 16 years ago)
Hi Michael,
Thanks for the easy question :)
Use the cursor keys to move the layer. Hold Shift to move in larger steps.
Use the keyboard controls only.
Selections can also snap onto grid lines and guides, which may suit your needs.
Use 'Select->Float' instead of (cut, then paste). Then you can move the floating layer as you desire.
- Michael
David
