strange workaround for slow GIMP start (WinXP) (resent)
strange workaround for slow GIMP start (WinXP) (resent) Cristian Secar? 26 Jun 18:51
  strange workaround for slow GIMP start (WinXP) (resent) Daniel Hornung 26 Jun 20:06
   strange workaround for slow GIMP start (WinXP) (resent) Cristian Secar? 26 Jun 23:11
    strange workaround for slow GIMP start (WinXP) (resent) Cristian Secar? 26 Jun 23:20
Cristian Secar?
2008-06-26 18:51:01 UTC (over 16 years ago)
(resent message, my original one sent on 24 Jun 2008 21:05:05 +0300 appers it never reaches the gimp-user destination)
After a system reinstall (HDD change) on my HP nc8230 notebook, GIMP was starting painfully slow, almost bloking itself at Fonts-something startup splash screen. This was something new for me, as in the previous WinXP system install GIMP started almost immediately.
Searching a bit I noticed that this happens to be a common issue on many Windows systems, where some have mentioned something about GTK+. This pointed me to the question - what was different in my previous system install related to GTK+ ? Answer - two more GTK+ applications (except for Sylpheed, which does not matter for the subject), Pidgin and GPA. So I installed Pidgin (2.4.2), et voilà, GIMP now starts immediately !
So who knows, maybe this info can be of some help for others too ... (and perhaps for GIMP developers too :)
Cristi
Daniel Hornung
2008-06-26 20:06:08 UTC (over 16 years ago)
Cristi
Have you tried starting GIMP twice without Pidgin installed? It could simply be that the very first start time takes very long for GIMP because it registers/ cashes all the available fonts and then only has to check for changes on the second and all subsequent starts.
Daniel
Cristian Secar?
2008-06-26 23:11:19 UTC (over 16 years ago)
Yes, I started it dozen of times, because currently I am working at the Romanian translation and during (say) ~1 hour of translation work I start and close the program almost each and every ~10 minutes in order to check my strings. These days I rarely use GIMP for image processing ...
Cristi
Cristian Secar?
2008-06-26 23:20:02 UTC (over 16 years ago)
Yes, I started it dozen of times, [...]
... other than that, I am not alone – the internet is full of complains about the program lock at fonts cache splash screen (on Windows). Maybe it is related to some particular method or detail used for Win32 compilation (?).
Cristi
