python-fu script
| python-fu script | peter kostov | 10 May 16:00 |
| python-fu script | Sven Neumann | 10 May 17:45 |
| python-fu script | Joao S. O. Bueno | 10 May 23:57 |
| python-fu script | David Gowers | 11 May 04:09 |
| python-fu script | Sven Neumann | 11 May 11:22 |
| python-fu script | Joao S. O. Bueno | 11 May 00:12 |
python-fu script
I am trying to write a python script. The problematic part of it is:
--- snip ---
def run_resynthesize(image, drawable, vtileable=1, htileable=1): defalut_args = (0, 0, 0, 0, 0.50, 0.12, 30, 200) args = list(defalut_args)
pdb.plug_in_resynthesizer(image,drawable,vtileable,htileable,*args)
def create_tileable(location, file_type_search, create_nmap,
texture_name, normal_map_name, save_as_type, new_img_location):
images = get_images(file_type_search, location)
num_images = len(images)
for i in range(num_images):
image = pdb.gimp_file_load(images[i]['image_file'],
images[i]['image_file'])
#drawable = PF_DRAWABLE
drawable = pdb.gimp_image_get_active_drawable(image)
#print drawable
run_resynthesize(image,drawable,1,1)
--- snip ---
I am getting a window listig several errors like this:
Procedure 'gimp-drawable-width' has been called with an invalid ID for argument 'drawable'. Most likely a plug-in is trying to work on a layer that doesn't exist any longer.
And an 'RuntimeError: execution error' message on the console.
I have googled, but not managed to find any answer :(
How should I get the 'drawable' and what exactly should I feed to the resynthesize plug-in as 'DRAWABLE'?
Please, please help!
Kind regards,
Peter
python-fu script
The drawable you are passing looks just right. But doesn't the resynthesizer PDB procedure take run-mode as its first parameter?
python-fu script
When caling PDB stuff from a python plug-in, the run-mode parameter is always omited and assumed to be "non-interactive"
python-fu script
--- snip ---
def create_tileable(location, file_type_search, create_nmap, texture_name, normal_map_name, save_as_type, new_img_location): images = get_images(file_type_search, location) num_images = len(images)
image = pdb.gimp_file_load(images[i]['image_file'], images[i]['image_file'])#drawable = PF_DRAWABLE drawable = pdb.gimp_image_get_active_drawable(image) #print drawable
run_resynthesize(image,drawable,1,1)--- snip ---
Hi. You should check the parameters passed to the resynthesizer plug-in I'd recomend testing it with one image from the python console, and check if the same error is raised
Once you have an image object, you can get it's top layer with image.layers[0] - no need to call pdb.gimp_image_get_active_drawable
To work, from the python console, on an image already open in gimp, just make a call to gimp.image_list() - it return a list of all open images as python objects.
js
Kind regards,
Peter
python-fu script
For the sake of completeness, I'll mention that you *can* use other run modes, by specifying the kwarg 'run_mode' like this
pdb.plug_in_gauss (i, i.layers[0], 4, 4, 1, run_mode = 0)
^^^ Brings up the normal interactive dialog.
python-fu script
That is a very bad design decision. How are you supposed to call a PDB function interactively then?
