two questions
two questions Kim Cascone 21 Apr 22:06
Kim Cascone
2008-04-21 22:06:07 UTC (about 17 years ago)
two questions
1- is there a way to make the guides visible outside the canvas area? - i.e. outside the non-visible canvas area for example: I have an '800x23' image and I want to drag out 'vertical' guides - but since the area is only 23 px tall the guides are very hard to see without a lot of zooming and scrolling around on a 15" laptop display
FWIW: Photoshop allows you to see the guides off the canvas and this comes in very handy at times
2- is there a script-fu script that will take an image/layer and chop it into table form
for example: I have a 100x100 image that I want to chop into 4 pieces, each being 50x50 then export all four of them in jpg/gif/png format
I then want to take these pieces and insert each one in a 2x2 table so they line up as a contiguous image - is there a script-fu anyone knows about that does this?
