trouble compiling gimp on Tru64 unix alphastation
trouble compiling gimp on Tru64 unix alphastation | <smt@beta.physics.uiowa.edu> | 04 Jun 00:02 |
I am trying to build gimp-1.2.3 on a new AlphaStation DS10 running Tru64 UNIX V5.1a. Both glib-1.2.9 and gtk+-1.2.9 compile and install with the gcc compiler using either gnu's make or the native make utility. glib won't build if I try to use the native cc compiler so I have to use gcc. The gimp configure script runs without trouble and make runs for a long time before it crashes. I've attached the tail of the error output from make as a text file. Are there any tru64 types out there that have some ideas?
Thanks in advance,
Scott Taylor
Systems Administrator
Physics & Astronomy
University of Iowa
This is the output from the gcc compiler and DEC's native make utility
bash-2.05a# make
No suffix list.
make all-recursive
No suffix list.
Making all in tools
Making all in intl
Making all in libgimp
Making all in app
/bin/ksh ../libtool --mode=link gcc -g -O2 -Wall -o gimp-1.2 -export-dynamic -export-symbols ./gimp.sym about_dialog.o airbrush.o app_procs.o asupsample.o batch.o bezier_select.o blend.o blob.o boundary.o brightness_contrast.o brush_edit.o brush_scale.o brush_select.o brush_select_cmds.o brushes_cmds.o bucket_fill.o by_color_select.o channel.o channel_cmds.o channels_dialog.o channel_ops.o channel_ops_cmds.o clone.o color_area.o color_balance.o color_cmds.o color_notebook.o color_panel.o color_picker.o color_select.o color_transfer.o colormaps.o colormap_dialog.o commands.o context_manager.o convert.o convert_cmds.o convolve.o crop.o cursorutil.o curves.o datafiles.o desaturate.o devices.o dialog_handler.o disp_callbacks.o display_cmds.o docindex.o dodgeburn.o draw_core.o drawable.o drawable_cmds.o edit_cmds.o edit_selection.o ellipse_select.o eraser.o errorconsole.o errors.o equalize.o fileops.o fileops_cmds.o flip_tool.o floating_sel.o floating_sel_
c!
mds.o file_new_dialog.o free_select.o fuzzy_select.o gdisplay.o gdisplay_ops.o general.o gimage.o gimage_mask.o gimpbrush.o gimpbrushgenerated.o gimpbrushlist.o gimpbrushpipe.o gimpcontext.o gimpcontextpreview.o gimpdnd.o gimphelp.o gimphistogram.o gimplist.o gimplut.o gimpparasite.o gimpprogress.o gimprc.o gimprc_cmds.o gimpui.o gimpunit.o global_edit.o gradient.o gradient_select.o gradient_select_cmds.o gradients_cmds.o gtkwrapbox.o gtkhwrapbox.o gtkvwrapbox.o guides_cmds.o gximage.o help_cmds.o histogramwidget.o histogram_tool.o hue_saturation.o image_cmds.o image_map.o image_new.o image_render.o indicator_area.o info_dialog.o info_window.o ink.o interface.o internal_procs.o invert.o iscissors.o layer.o layer_cmds.o layer_select.o layers_dialog.o lc_dialog.o levels.o lut_funcs.o magnify.o main.o measure.o menus.o message_cmds.o misc_cmds.o module_db.o move.o nav_window.o ops_buttons.o palette.o palette_cmds.o palette_select.o paint_core.o paint_fun
c!
s.o paintbrush.o parasite_cmds.o parasitelist.o path.o paths_cmds.o paths_dialog.o pattern_select.o pattern_select_cmds.o patterns.o patterns_cmds.o pencil.o perspective_tool.o pixel_processor.o pixel_region.o plug_in.o plug_in_cmds.o posterize.o preferences_dialog.o procedural_db.o procedural_db_cmds.o qmask.o rect_select.o regex.o resolution_calibrate.o resize.o rotate_tool.o scale.o scale_tool.o scan_convert.o scroll.o selection.o selection_cmds.o session.o shear_tool.o smudge.o temp_buf.o text_tool.o text_tool_cmds.o threshold.o tile.o tile_cache.o tile_manager.o tile_swap.o tips_dialog.o tool_options.o tools.o tools_cmds.o transform_core.o transform_tool.o undo.o undo_cmds.o undo_history.o unit_cmds.o user_install.o xcf.o libgimpim.a ../libgimp/libgimpi.a -L/usr/local/lib -lgtk -lgdk -lgmodule -lglib -lXext -lXext -lX11 -ldnet_stub -lm
gcc -g -O2 -Wall -o gimp-1.2 about_dialog.o airbrush.o app_procs.o asupsample.o batch.o bezier_select.o blend.o blob.o boundary.o brightness_contrast.o brush_edit.o brush_scale.o brush_select.o brush_select_cmds.o brushes_cmds.o bucket_fill.o by_color_select.o channel.o channel_cmds.o channels_dialog.o channel_ops.o channel_ops_cmds.o clone.o color_area.o color_balance.o color_cmds.o color_notebook.o color_panel.o color_picker.o color_select.o color_transfer.o colormaps.o colormap_dialog.o commands.o context_manager.o convert.o convert_cmds.o convolve.o crop.o cursorutil.o curves.o datafiles.o desaturate.o devices.o dialog_handler.o disp_callbacks.o display_cmds.o docindex.o dodgeburn.o draw_core.o drawable.o drawable_cmds.o edit_cmds.o edit_selection.o ellipse_select.o eraser.o errorconsole.o errors.o equalize.o fileops.o fileops_cmds.o flip_tool.o floating_sel.o floating_sel_cmds.o file_new_dialog.o free_select.o fuzzy_select.o gdisplay.o gdisplay_ops.o general.o gimage.o g
i!
mage_mask.o gimpbrush.o gimpbrushgenerated.o gimpbrushlist.o gimpbrushpipe.o gimpcontext.o gimpcontextpreview.o gimpdnd.o gimphelp.o gimphistogram.o gimplist.o gimplut.o gimpparasite.o gimpprogress.o gimprc.o gimprc_cmds.o gimpui.o gimpunit.o global_edit.o gradient.o gradient_select.o gradient_select_cmds.o gradients_cmds.o gtkwrapbox.o gtkhwrapbox.o gtkvwrapbox.o guides_cmds.o gximage.o help_cmds.o histogramwidget.o histogram_tool.o hue_saturation.o image_cmds.o image_map.o image_new.o image_render.o indicator_area.o info_dialog.o info_window.o ink.o interface.o internal_procs.o invert.o iscissors.o layer.o layer_cmds.o layer_select.o layers_dialog.o lc_dialog.o levels.o lut_funcs.o magnify.o main.o measure.o menus.o message_cmds.o misc_cmds.o module_db.o move.o nav_window.o ops_buttons.o palette.o palette_cmds.o palette_select.o paint_core.o paint_funcs.o paintbrush.o parasite_cmds.o parasitelist.o path.o paths_cmds.o paths_dialog.o pattern_select.o pattern_select_cmds.o pa
t!
terns.o patterns_cmds.o pencil.o perspective_tool.o pixel_processor.o pixel_region.o plug_in.o plug_in_cmds.o posterize.o preferences_dialog.o procedural_db.o procedural_db_cmds.o qmask.o rect_select.o regex.o resolution_calibrate.o resize.o rotate_tool.o scale.o scale_tool.o scan_convert.o scroll.o selection.o selection_cmds.o session.o shear_tool.o smudge.o temp_buf.o text_tool.o text_tool_cmds.o threshold.o tile.o tile_cache.o tile_manager.o tile_swap.o tips_dialog.o tool_options.o tools.o tools_cmds.o transform_core.o transform_tool.o undo.o undo_cmds.o undo_history.o unit_cmds.o user_install.o xcf.o libgimpim.a ../libgimp/libgimpi.a -L/usr/local/lib /usr/local/lib/libgtk.so /usr/local/lib/libgdk.so /usr/local/lib/libgmodule.so /usr/local/lib/libglib.so -lXext -lX11 -ldnet_stub -lm
gettext
bindtextdomain
textdomain
dgettext
collect2: ld returned 1 exit status
*** Exit 1
Stop.
*** Exit 1
Stop.
*** Exit 1
Stop.
bash-2.05a#
This is the output from the gcc compiler and gnu's make utility (gmake)
bash-2.05a# gmake
gmake all-recursive
gmake[1]: Entering directory `/usr/local/share/gimp-1.2.3'
Making all in tools
gmake[2]: Entering directory `/usr/local/share/gimp-1.2.3/tools'
gmake[3]: Entering directory `/usr/local/share/gimp-1.2.3/tools'
gmake[3]: Nothing to be done for `all-am'.
gmake[3]: Leaving directory `/usr/local/share/gimp-1.2.3/tools'
gmake[2]: Leaving directory `/usr/local/share/gimp-1.2.3/tools'
Making all in intl
gmake[2]: Entering directory `/usr/local/share/gimp-1.2.3/intl'
gmake[2]: Nothing to be done for `all'.
gmake[2]: Leaving directory `/usr/local/share/gimp-1.2.3/intl'
gmake[2]: Entering directory `/usr/local/share/gimp-1.2.3/libgimp'
gmake[2]: Leaving directory `/usr/local/share/gimp-1.2.3/libgimp'
Making all in app
gmake[2]: Entering directory `/usr/local/share/gimp-1.2.3/app'
/bin/ksh ../libtool --mode=link gcc -g -O2 -Wall -o gimp-1.2 -export-dynamic -export-symbols ./gimp.sym about_dialog.o airbrush.o app_procs.o asupsample.o batch.o bezier_select.o blend.o blob.o boundary.o brightness_contrast.o brush_edit.o brush_scale.o brush_select.o brush_select_cmds.o brushes_cmds.o bucket_fill.o by_color_select.o channel.o channel_cmds.o channels_dialog.o channel_ops.o channel_ops_cmds.o clone.o color_area.o color_balance.o color_cmds.o color_notebook.o color_panel.o color_picker.o color_select.o color_transfer.o colormaps.o colormap_dialog.o commands.o context_manager.o convert.o convert_cmds.o convolve.o crop.o cursorutil.o curves.o datafiles.o desaturate.o devices.o dialog_handler.o disp_callbacks.o display_cmds.o docindex.o dodgeburn.o draw_core.o drawable.o drawable_cmds.o edit_cmds.o edit_selection.o ellipse_select.o eraser.o errorconsole.o errors.o equalize.o fileops.o fileops_cmds.o flip_tool.o floating_sel.o floating_sel_cmds.o file_new_dialog
o free_select.o fuzzy_select.o gdisplay.o gdisplay_ops.o general.o gimage.o gimage_mask.o gimpbrush.o gimpbrushgenerated.o gimpbrushlist.o gimpbrushpipe.o gimpcontext.o gimpcontextpreview.o gimpdnd.o gimphelp.o gimphistogram.o gimplist.o gimplut.o gimpparasite.o gimpprogress.o gimprc.o gimprc_cmds.o gimpui.o gimpunit.o global_edit.o gradient.o gradient_select.o gradient_select_cmds.o gradients_cmds.o gtkwrapbox.o gtkhwrapbox.o gtkvwrapbox.o guides_cmds.o gximage.o help_cmds.o histogramwidget.o histogram_tool.o hue_saturation.o image_cmds.o image_map.o image_new.o image_render.o indicator_area.o info_dialog.o info_window.o ink.o interface.o internal_procs.o invert.o iscissors.o layer.o layer_cmds.o layer_select.o layers_dialog.o lc_dialog.o levels.o lut_funcs.o magnify.o main.o measure.o menus.o message_cmds.o misc_cmds.o module_db.o move.o nav_window.o ops_buttons.o palette.o palette_cmds.o palette_select.o paint_core.o paint_funcs.o paintbrush.o parasite_cmds.o parasitelist.
o!
i!
t!
gettext
bindtextdomain
textdomain
dgettext
gmake[2]: *** [gimp-1.2] Error 1
gmake[2]: Leaving directory `/usr/local/share/gimp-1.2.3/app'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/usr/local/share/gimp-1.2.3'
gmake: *** [all-recursive-am] Error 2
bash-2.05a#
