stroking path with 1 pixel width brush is semiopaque
5 of 6 messages available
stroking path with 1 pixel width brush is semiopaque dorai iyer 25 Mar 19:51
  stroking path with 1 pixel width brush is semiopaque Daniel Hornung 25 Mar 21:56
   stroking path with 1 pixel width brush is semiopaque GSR - FR 25 Mar 22:19
   stroking path with 1 pixel width brush is semiopaque dorai iyer 26 Mar 06:08
47E9548F.8080802@aol.com 07 Oct 20:19
  stroking path with 1 pixel width brush is semiopaque dorai iyer 25 Mar 21:19
dorai iyer
2008-03-25 19:51:04 UTC (about 17 years ago)
I selected a 1 pixel thick brush to stroke the drawn path onto an image. When I stroked the path, the color of the stroke appears semi transparent. Is there a way to make it appear completely solid. Thanks
dorai iyer
2008-03-25 21:19:06 UTC (about 17 years ago)
Thanks but Cloning does not explain why the drawn stroke does not appear solid, it appears semitransparent also I am not trying to remove a feature.
On Tue, Mar 25, 2008 at 12:37 PM, Hans Mull wrote:
transparent.
Daniel Hornung
2008-03-25 21:56:34 UTC (about 17 years ago)
You could turn off antialiasing (extension of the stroke dialog under "line style") or use the pencil as "paint tool" there with a 1 pixel brush, these two methods look equivalent to me. You might have noticed that you have full color pixels where the path goes straight across a pixel, but less when the pixel is only touchedm this is due to the antialiasing that's on by default.
This will give a fully colored, 1-pixel line: -------------------------
| x-|---|---|---|---|-x |
This will give a 50% colored, 2-pixel line: -------------------------
--x-------------------x--
I hope this helped a bit to understand the problem.
Greetings, Daniel
GSR - FR
2008-03-25 22:19:59 UTC (about 17 years ago)
daniel.hornung@gmx.de (2008-03-25 at 2156.34 +0100):
Add that 50% pixel intensity does not have to match 50% light intensity (gamma), and the problem becomes more obvious.
GSR
dorai iyer
2008-03-26 06:08:07 UTC (about 17 years ago)
Thanks, antialiasing was the problem. Appreciate the explanation.
transparent.
Greetings, Daniel
