GTK+ print or gutenprint?
GTK+ print or gutenprint? Geoffrey 17 Mar 12:36
  GTK+ print or gutenprint? Sven Neumann 18 Mar 08:42
Geoffrey
2008-03-17 12:36:31 UTC (about 17 years ago)
I'm curious as to which would be the preferred print functionality? I've noticed both options but can't really tell much difference in the quality of the output.
2008-03-18 08:42:15 UTC (about 17 years ago)
The GTK+ print system doesn't deal with driving the printers, it is only a user interface on top of your print system. Under the hood, this system is most likely using Gutenprint printer drivers (at least for inkjet type of printers). So it doesn't really matter from a quality of output point of view. The Gutenprint plug-in perhaps gives you a little more control over the output, the "official" GIMP Print plug-in is probably easier to use.
